Front SDU overall width?
Posted: Fri Aug 07, 2020 12:25 am
Anyone with a Front SDU laying around? Curious what the overall width is on one of these.
openinverter Community
https://openinverter.org:443/forum/
Ive had that downloaded for a while.P.S.Mangelsdorf wrote: ↑Fri Aug 07, 2020 1:44 pm https://grabcad.com/library/tesla-front ... -3d-scan-1
Does not, should measure right. Atleast it does for me.jon volk wrote: ↑Fri Aug 07, 2020 5:45 pmIve had that downloaded for a while.P.S.Mangelsdorf wrote: ↑Fri Aug 07, 2020 1:44 pm https://grabcad.com/library/tesla-front ... -3d-scan-1
The scaling goes to shit when I import it to Fusion360. I need some sort of stable reference point.
I was able to download an f3d format file. That worked fine. .stl's always screw me up.SciroccoEV wrote: ↑Fri Aug 07, 2020 11:47 pm STL files are dimensionless. Engineering units are either mm or inches (people who use centimeters should be slowly beaten to death with wooden rulers).
If the scaling is wrong, then try importing the file with you units set differently.
