Parameters Losing Value
Posted: Tue Mar 26, 2019 3:36 am
While testing my inverter in manual mode I've noticed the motor will stop running after some random amount of time has elapsed. When I investigate I find that 2 parameters have lost their values. The two parameters which are losing value are fslipspnt and ampnom.
While testing I set the values of fslipspnt = 10 and ampnom = 60. When the motor stops I check the values and they have changed to fslipspnt = -1.62 and ampnom = 0.06.
When I check the errors sometimes an error is reported with no error message, other times there are no errors recorded.
I can reproduce this same failure many times after resetting the parameters, and even after disconnecting power and powering back on. The parameters always seem to return to these same values.
Have I corrupted the firmware?
