Military grade jamming
Posted: Sat Jun 13, 2020 2:39 pm
Went out to do some work on the Deranged Rover. Found I couldn't connect to the wifi. Took logic board into shed. Connects fine. Back to car, no connection. Hours of fault finding ensues. Find I can't connect to any of my cars inverter wifi out in the drive. Take em into the shed, connect fine. Recently a company here started offering broadband over wifi. Grabbed a wifi analyser from the play store. Yep. Two masts blasting out signal over 10 channels! Changed one line of code in the esp8266 firmware to select channel 14. Perfect connections.
WiFi.softAP(server.arg("apSSID").c_str(), server.arg("apPW").c_str(),14); //set channel here
