Regen issue
Posted: Thu Jun 11, 2020 4:52 pm
by Peter
Hello Forum. Looking for some advice here please. I have set up basic trial regen parameters (I am using a Combi V8 board driven inverter) and try a basic regen with motor off load I can see the braking effect and reverse current but then I have to power down and restart the inverter to be able to run again, any clues please ?
Parameters..
Brake pedal pressed
Regen pot set at 0v or 5v makes no difference (need to sort pot use later)
pot2min 4095
pot2max 4095
SingleRegen set
brknompedal -30
brkpedalramp 5
brknom 0
brkmax 0
brkrampstr 10
brkout -10
Thanks in advance for any suggestions. Peter
Re: Regen issue
Posted: Sat Jun 13, 2020 10:30 am
Why do you have to power down and restart? What happens otherwise?
Re: Regen issue
Posted: Sat Jun 13, 2020 3:10 pm
by Peter
Hello Johannes. Thank you for your reply. The inverter will not allow the motor to run again unless I power down and restart.
Re: Regen issue
Posted: Sat Jun 13, 2020 3:40 pm
by Peter
Hi Johannes. Just as a reminder I am using Revision 1. Peter
Re: Regen issue
Posted: Sat Jun 13, 2020 3:44 pm
by joromy
Peter wrote: Thu Jun 11, 2020 4:52 pm Hello Forum. Looking for some advice here please. I have set up basic trial regen parameters (I am using a Combi V8 board driven inverter) and try a basic regen with motor off load I can see the braking effect and reverse current but then I have to power down and restart the inverter to be able to run again, any clues please ?
Please give us some more info, like fault messages.
Does is restart without regen?
Do you use the web interface?
Re: Regen issue
Posted: Sat Jun 13, 2020 3:46 pm
by Peter
Hi Joromy. I do use the web interface, I am copying the spot values etc to post on the forum later.
Re: Regen issue
Posted: Sat Jun 13, 2020 3:47 pm
by Peter
Hi again Johannes. I am using 4.59 software, would it be better to use the latest now as you have made so may improvements ?
Re: Regen issue
Posted: Sat Jun 13, 2020 3:54 pm
by joromy
What do you get if you click the "Display Error Memory" button, after start and when the inverter is not starting again
Re: Regen issue
Posted: Sat Jun 13, 2020 7:17 pm
Peter wrote: Sat Jun 13, 2020 3:47 pm Hi again Johannes. I am using 4.59 software, would it be better to use the latest now as you have made so may improvements ?
You can always try as you can just downgrade if you run into issues.
I have no idea what changes I made since.
Re: Regen issue
Posted: Sat Jun 13, 2020 8:48 pm
by Peter
Hi Johannes. My apologies the software is listed as 4.87 on the spot values. Peter
Re: Regen issue
Posted: Sun Jun 14, 2020 10:30 am
by Peter
Have attached spot value and parameter files. Thanks in advance for all your help.
Re: Regen issue
Posted: Thu Jun 18, 2020 11:53 am
Can you set fmin to 0.3 and try again?
Re: Regen issue
Posted: Thu Jun 18, 2020 3:29 pm
by Peter
Hi Johannes. Will try and report back, fingers crossed :-) Thanks. Peter
Re: Regen issue
Posted: Thu Jun 18, 2020 5:45 pm
by Peter
Hi Johannes. Has anyone ever told you that you are a genius ?? If not may I be the first to say so :-)
My next task is to use the regen pot to control how much regen when brake pedal pressed.
Re: Regen issue
Posted: Thu Jun 18, 2020 7:41 pm
Good to hear :)
I think I'm gonna delete that fmin parameter and hard code it to a very low value. It's caused a lot of trouble.
Re: Regen issue
Posted: Thu Jun 18, 2020 9:16 pm
by Isaac96
johu wrote: Thu Jun 18, 2020 7:41 pm Good to hear :)
I agree, it especially causes problems with low min slip settings. Are there any possible problems from setting it too low?
-Isaac
Re: Regen issue
Posted: Thu Jun 18, 2020 9:25 pm
Isaac96 wrote: Thu Jun 18, 2020 9:16 pm I agree, it especially causes problems with low min slip settings. Are there any possible problems from setting it too low?
-Isaac
No the only goal is to have a 0 amplitude criteria. I guess I'll hard-code 0.2Hz
