Flashing .bin via web interface always corrupts?
Posted: Sun May 24, 2020 11:39 pm
Hoping to check if I'm doing anything wrong here... Setup:
-Standard web interface
-Tesla SDU V4 board (with the watchdog reset pin fix from V6)
-Current version (4.85R)
-Web interface works flawlessly otherwise.
-I'm adding the stm32_sine.bin into the upload box and pressing upload
-Status box says upload complete, and then goes from 0-100% in around 5 seconds. Green light on wifi module flashes green during this time.
-Nothing happens after this, the "run" LED on the inverter board no longer flashes. Restarting the board does nothing.
-Even while in this broken state, I can redo the upload and the exact same as above happen, including progress bar
Only way to get board back is to reflash via SWD, but this requires pulling the drive unit apart. Have tried reflashing the bootloader
Any ideas?
Any ideas?
