Prius Gen2 PWM waveforms
Posted: Sun May 17, 2020 3:58 am
Hello,
I just purchased a Prius Gen2 inverter module and I want to run some experiments on it. I have downloaded the wiring diagrams that show the connections to the hybrid ECU, but I still have a few questions:
1. How does the HV-ECU command a full wave, if there is only one line per phase? I thought that one needs 2 signals: one to control the high side transistor, one to control the low side transistor.
2. What are the voltage levels for the PWM? I have read somewhere that the booster module requires 10Vpp PWM. Is the same true for the inverters?
3. Are there any online resources, or perhaps some tutorials regarding this matter?
