Calibration of current sensors Melexis.
Posted: Tue Mar 12, 2019 7:12 pm
Hello - so I placed all the elements on the printed circuit boards and it is time to calibrate the current sensors. From the descriptions on the page: https://openinverter.org/docs/index.htm ... ons,9.html
Here I didn’t understand anything, it is possible in more detail how to calibrate current sensors MLX91208.To calibrate the current, set il1gain and il2gain to 1. Then put a known current through the sensors by winding for example a 1.5mm² cable 10 times through both sensors. Then, using you lab power supply run 5A through your wound cable. Type:
