Page 1 of 1
How- regen control with pressure sensor
Posted: Fri Apr 10, 2026 6:48 pm
by CapriV
Can someone explain how I can implement a (2000psi, 0.5 - 4.5v) brake line pressure sensor to increase regen in parallel to brake force, in the zombieverter.
Re: How- regen control with pressure sensor
Posted: Fri Apr 10, 2026 9:34 pm
by arber333
CapriV wrote: ↑Fri Apr 10, 2026 6:48 pm
Why complicate with pressure? You could use linear pot 5K to return 0V to 5V signal. You put this under your brake pedal together with brake switch.
Then you can program zombie with your selection of curve...
https://uk.farnell.com/tt-lm10-potentiometer
https://www.aliexpress.com/i/1005006263163326.html
Posted: Sat Apr 11, 2026 12:39 am
by tom91
Zombie only does an on off brake sensor. There is no Analogue input for brake position thus regen request mapping.
Regen level change is only done on speed.
Posted: Mon Apr 13, 2026 12:58 pm
by CapriV
True. Could do it that way too, but it seems this is a no go feature anyways. Thanks!
