Porsche 996 Smal S drive unit from Elon
Posted: Tue Mar 10, 2026 6:27 pm
by Markusvolvo
I'm in the planning stages of this build.
Have decided on a Tesla model s Smal drive unit. This for 300hp original and that the orientation fits quite well, from a model 3 the motor is facing the wrong way and will take in from below, ass in the floor "back seat"
My big question to you guys out there is which control system do you recommend?
And what batteries would you use?
Please tell me what components you would use for a project like this.
Re: Porsche 996 Smal S drive unit from Elon
Posted: Tue Mar 10, 2026 6:37 pm
by Markusvolvo
- Tesla smal drive unit rear.jpg (6.07 KiB) Viewed 407 times
The Motor, Behold
Posted: Sat Mar 14, 2026 11:03 pm
by modellfan
I can’t tell which battery but I can tell you how I decided in my 986. Measure axle weights when striped down. Estimate how much weight you have left on which axle . Scan with an iPhone or measure manually potential volume of the battery box .
Try to find a battery that matches axle loads , volume, max necessary current for SDU 650A . Use the battery module wiki page and play 3D Tetris .
If you focus power go for hybrid batteries , if range , you propably need to split the battery box in a front and a rear box
Posted: Tue Mar 31, 2026 7:40 pm
by steveknox
Look on grabcad for my 3d scan of the 996 engine bay. Saves a lot of heavy lifting and figuring out of angles and fitment! I struggled to make the model S rear fit so went for the front one (which is also very tight).
Posted: Sat Apr 25, 2026 5:56 pm
by E46Kim
Hi i have installed the front small drive unit and it is very tight. I can share more fotos on Monday
Posted: Sun Apr 26, 2026 6:54 pm
by Bigpie
I'd be interested to see more photos. I've been mounting the same motor in an 996 also.
Posted: Sun Apr 26, 2026 7:10 pm
by Markusvolvo
Okay it's there now, but I'll have to rebuild all the mounting points as the anti-roll bar will kick in, the electric motor is too low, ground clearance is a problem, I don't want the motor to be the lowest point. but it'll do.
What batteries & BMS are you guys planning to run?
Posted: Mon Apr 27, 2026 12:06 pm
by steveknox
I notice that your previous picture is the front SDU, and these most recent ones are the rear SDU. Did you change design or have I missed something?
