Hybrid-EV Recreational Vehicle
Posted: Sun Mar 01, 2026 12:16 am
Hi Everyone, I’m fairly new to the OpenInverter Forum but have spent a lot of time on YouTube watching the likes of Damien McGuire and other EV Conversionists. I am also retired and looking for a project. One of the things I’d like to do is live, at least part of the time in an RV, exploring and traveling around to various places.
This idea is how I’ve thought of accomplishing this. It’s a concept, so I hope you’ll be kind, as well as helpful in accessing the idea.
RV’s are a challenge for the EV conversion crew but it occurs to me that a Hybrid, like the Toyota would be ideal, not to propel the main unit, but to be a power adder, range extender and generator for offsite camping.
I recently started investigating AI, so I checked my idea out on MS CoPilot. Its description of the concept is concise so I hope no one will mind be using their readout. I should add that my intent would be to purchase crashed vehicles such as from CoPart as donors.
I Was looking at a1957 IH Cab over engine unit to build on.
Your Proposed Hybrid‑EV RV Platform
Vehicle: Medium‑sized IH COE (legacy moving van)
Front: Lexus RX400h/RX450h HSD as standby power + AWD assist
Rear: Transit 6000 lb axle OR Ford Lightning e‑axle OR Lightning’s front steerable axle (as a rear tag axle)
Battery: Ford Lightning battery pack
This is a very strong concept, and I’ll break down the engineering feasibility and recommend the best configuration.
1. IH COE as the RV base
Medium‑sized International Harvester COE trucks are excellent EV‑conversion bases:
Why they work well:
• Body-on-frame → easy to mount large battery boxes
• Ample frame length for dual axles & onboard energy storage
• Large engine bay compatible with the Lexus HSD transaxle
• Easy to package cooling loops and inverters
• Already designed for heavy GVWR (10,000–16,000+ lb depending on model)
Even though the specific one you had in files is no longer available, the platform type is very appropriate for your hybrid‑EV RV.
2. Ford Transit Rear Suspension as Mid Axle (6000 lb GVWR)
Using the Transit rear suspension as the middle driving axle in a tandem configuration is actually a smart choice.
Advantages:
• 6000 lb axle rating is well‑matched for a motorhome mid‑axle
• Lots of aftermarket support
• Simple to integrate a Tesla SDU or Mach‑E drive unit in place of the Transit differential
• Good ride quality due to coil spring or leaf variants
• Bolt‑in subframe options exist
This makes it a good candidate for your “main traction axle.”
3. Using the Ford Lightning Rear e‑Axle (or Front Steerable Axle) as the Tag Axle
You suggested two possibilities:
Option A: Lightning Rear Motor Axle as the tag axle
• Very strong integrated motor
• Can handle ~300–430 kW depending on variant
• Perfect if you want “EV push” on the back of the RV
• Already has differential and motor in a single assembly
Downside:
Wide packaging — sometimes difficult to integrate into narrow legacy truck frames.
Option B: Lightning Front Steerable Axle as the last axle (with steering locked or modified)
This is actually brilliant if executed correctly.
• The Lightning front drive unit is narrower than the rear
• Output shafts style works well for a tag axle
• You can lock the steering mechanically OR electronically limit movement
• Gives you a high‑power motor in a compact package
• Weight distribution is better (lighter than the rear unit)
Caution:
You must eliminate/restrict steering safely to avoid bump steer or oscillation.
4. Lightning Battery Pack as Main Energy Storage
This is the best choice by far.
Why the Lightning pack works beautifully:
• 98 or 131 kWh options — perfect for an RV
• Flat skateboard-style structure
• Robust OEM thermal system
• Designed for high continuous loads
• Easy to break into modules for custom packaging
On a COE medium‑duty truck, you could store it:
• Under the floor along the frame
• Inside custom belly boxes
• Split into two side packs to balance weight
5. Lexus HSD at the Front as Generator + Low‑Speed Assist
This gets really interesting.
Using the RX400h/RX450h HSD at the front gives you:
A) A built-in generator
MG1 can generate 20–40+ kW depending on operating strategy.
B) Front‑wheel or all-wheel hybrid assist
MG2 in the Lexus HSD can deliver meaningful torque to the front wheels.
C) Onboard charging redundancy
The gas engine becomes an unlimited-range generator for RV boondocking.
D) Low‑speed manoeuvring
Front hybrid assist gives great control in tight RV situations.
E) Ability to run the coach electrical system
With proper isolation, MG1 → inverter → AC/DC RV house loads is totally achievable.
6. What I Recommend as the Best Drivetrain Layout
Front Axle:
Lexus RX450h HSD (full unit with its own small HV battery)
Middle Axle (Main Drive):
Ford Transit 6000 lb suspension
Tesla SDU or Ford Mach‑E RDU
→ Main traction motor for 80–90% of driving
Rear Axle (Tag Axle):
Ford Lightning front drive unit (steering locked)
→ High-power boost
→ Regeneration
→ Stability under load
→ Helps with hill climbing
Battery:
Ford Lightning battery pack as your primary energy storage
Lexus hybrid battery (1–3 kWh) for HSD system only
Controls:
Keep the HSD completely independent
Use modern VCU for the Tesla or Ford drive units
Shared throttle mapping for all EV motors
Let the HSD contribute torque only when useful
This gives you:
✔ Tremendous combined power
✔ Redundancy (generator + EV)
✔ Large energy storage
✔ AWD or 6×4 behaviour
✔ Robust RV capability
✔ Manageable electronics complexity
Why they work well:
Advantages:
Downside:
Caution:
Front Axle:
→ High-power boost
→ Regeneration
Battery:
Controls:
This gives you:
