Tesla LDU Inverter Control Board 1013416-00-E REV03 — DI_F072 fault — EEPROM reset help needed
Olo3323
Post by Olo3323 »
Hello everyone,
I'm working on repairing a Tesla Large Drive Unit inverter
control board with the following details:
Part number: 1013416-00-E REV03
Serial: 2116E60000795
Fault: DI_f072_gateDriverFaultCounter / DI_w072
The drive unit has been removed from the vehicle and is
on the bench.
IGBT diode test results:
- All phases show approximately 0.4-0.5V in diode mode
- No short circuit detected (0.000V)
- Gate resistors appear to be in normal range (not in MΩ)
Based on this, I believe the IGBT modules are physically
OK and the fault is latched in the EEPROM of the control
board — not a hardware failure.
My questions:
1) Can anyone confirm that DI_F072 on this specific board
(1013416-00-E) is stored/latched in the EEPROM chip?
2) What is the exact EEPROM chip type on this board?
(95128? 95256? other?)
3) Does anyone know the hex offset / address in the EEPROM
where the fault counter is stored?
What bytes need to be zeroed out to clear DI_F072?
4) I have a CH341A programmer and SOIC8 clip ready.
Is it safe to read/write the EEPROM in-circuit
(without desoldering)?
I have already read about EV Clinic file service as an
option, but I would prefer to understand the process
myself first if anyone has already reverse-engineered
this.
I can share my EEPROM dump here if that would help
the community document this for future repairs.
Thank you very much in advance!
Isle
Re: Tesla LDU Inverter Control Board 1013416-00-E REV03 — DI_F072 fault — EEPROM reset help needed
Post by Isle »
Hey, were you ever able to figure this out?
I have the exact same issue and have been trying to fix it for a while! In my case, there was a bad IGBT diode but I replaced the phase module, yet the error still remains.
I also read about the EV clinic one but I don't want to spend more money than a board costs to have them do it, this can't be impossible to figure out.
