Does Prius gas pedal contain electronics
Posted: Wed Jan 28, 2026 1:41 pm
The wiki says power it with 5v, but I'm using a 3.3v Teensy.
Does the pedal contain electronics that need 5v, or is just a pair of pots with gnd and vcc across the resistor ?
I can scale the return to 3.3v, but i'd rather not if its not required and i can use 3.3v across it.
