Page 1 of 1
VW Passat GTE Battery
Posted: Mon Jan 19, 2026 11:56 am
by arber333
I offer two 9kWh Passat GTE 8x module blocks with cooling blocks and BCM with each.
For each block i made wiring to connect to SimpBMS Teensy 3.2.
I offer each battery block of 8 modules with functioning Simp BMS, wiring and LCD for 1100€ + shipping.
Location is Slovenia EU. If you have pickup option i can adapt...
Some photos and demonstration of application :).
https://leafdriveblog.wordpress.com/202 ... o-simpbms/
https://leafdriveblog.wordpress.com/202 ... er-part-1/
Let me know in PM
Re: VW Passat GTE Battery
Posted: Tue Jan 20, 2026 7:06 am
by versedpiano
I've read the article. The Passat GTE 9kWh battery using SimpBMS looks quite good 👍
I have a further question: What is the current remaining capacity of the battery in percentage?
Posted: Tue Jan 20, 2026 9:50 am
by arber333
versedpiano wrote: Tue Jan 20, 2026 7:06 am ....
I am not sure. Never tested. I was using those cells as Ampera extender throughout the year and in winter i removed it in my workshop for use as a test pack. Pack never went below 3.3V per cell because Ampera stops discharge at 30% SOC.
I will try to find a way to discharge the pack to 3V per cell and charge it back to 4.1V per cell and probably record energy transfered.
I could wire them in paralell for 8P12S using solar inverter and get 2kw water heater and spend kW to heat up 300L of water :twisted: What could possibly go wrong.
Posted: Wed Mar 18, 2026 7:42 am
by arber333
arber333 wrote: Tue Jan 20, 2026 9:50 am I am not sure. Never tested. I was using those cells as Ampera extender throughout the year and in winter i removed it in my workshop for use as a test pack. Pack never went below 3.3V per cell because Ampera stops discharge at 30% SOC.
I had a lot on my hands lately... i will test capacity soon and it is not expected to be less than 8kWh.
If anyone is interested to buy as is i can tweak the price for EU at 900€ + shipping for 8 modules with functioning Simp BMS, wiring and LCD
I have two of the packs available here.
Posted: Sat Apr 18, 2026 9:03 am
by arber333
Still for sale...
