Leaf Gen2 Heatsink temperature sensor
Posted: Sun Apr 12, 2020 7:39 pm
When designing the Leaf expansion board I had clearly found a signal that correlated with the temperature of water I put into the cooling channels. The signal is PWM, 500Hz if I remember correctly, but it is not important here.
Here is what I found:
18°C 46,50%
25°C 48,60%
30°C 50,12%
35°C 51,90%
40°C 53,43%
I extrapolated a few more values from that curve, down to -10 and up to 100°C. But now it doesn't work. The value is now 30% at 20°C and thus the temperature is stuck at -10°C
To get at least something I just subtracted 15% from all dutycycles, now I get a very strange behaviour. The supposed temperature rises by up to 50°C within a second when accelerating hard but also drops at the same speed when coming off the accelerator. So I'm not sure if what I'm seeing is really the temperature.
Could anyone do a temp test with their Leaf inverter? The signal I use is on CN501 pin 14.
18°C 46,50%
25°C 48,60%
30°C 50,12%
35°C 51,90%
40°C 53,43%
