Choosing Leaf components for a conversion
Posted: Tue Dec 09, 2025 12:05 am
I would like to convert a 2004 Subaru Baja awd Turbo 5spd manual to electric using Nissan Leaf components. The turbo motor output 210hp and 235 torque.
I have been collecting stuff over the years. Most stuff I just came across and picked up at very low costs.
I have a three leaf motors. 2012 , 2015 and a 2017.
The 2017 is a complete car and will move. but totalled. I should be able to use any drive train part I need. 40 kwh battery.
I have a 2015 motor and tranny.
I don't think I have the inverter.
The 2012 is a complete car and drives. But it only goes 33 miles. All cells are degraded equally.
I have a separate 24kwh leaf lizard pack that was a battery warranty replacement. Only about one year of use on it but at least 4 years old.
I have a 60kwh bolt battery. Along with motor and tranny and i think inverter. Not sure on year. Maybe the charger and a fluid heater
And I have all 9 modules from a rivian that had about 50 miles on it.
And I have a 2008 prius inverter that may or may not he working.
I have herd that the 2012 leaf motors were over built and could get more hp and torque then the other leaf motors if set up correctly
I have limited knowledge of the vcu options. And don't know if I can use any battery pack I want or need to stick with leaf cells..
Let me know what you think.
I did see you Subaru Brat conversion years ago on YouTube.
I think I got advice from the maker of openinvrter to just sell the 2012. "To difficult to work with.
And probably will want to keep the 2012 Leaf as a running car.
And if the 2012 motor is more desirable because of being over built with stronger rare earth magnets. I could try to find one of those.
I am not in need of maximum hp and torque.
But if I can get more with one component. Change. I might be up for it. I probably don't want to go beyond the 210hp and 235 torque of the original engine. I don't want to blow up the tranny.
