new here and i think I'll jump right in 2014 I3 issues
NE555
Post by NE555 »
Thank you all for letting me join.
My wife and I bought an 2014 bmw i3 from a repo auction.
Once I got the car home and hooked up to Ista +, I saw that the VIN in the BCM differs from the cars VIN on the frame and paperwork.
I appears someone has swapped in the BDC from a different i3 and didn't code in the FA or register the correct VIN to the BDC.
We managed to code the right vin to the BDC and straighten out the FA. But the car will not move , IMMO is activated I believe with an error.
21E921 electronic Immobilizer: non authentic response received.
what to do in order to get the ISN (I presume) in the EME changed to match the request from the BDC?
Or what do we need to do in order to remedy this?
thank you, and I know its a deep dive for a first introductory post.
Has thanked: 365 times
Been thanked: 249 times
Re: new here and i think I'll jump right in 2014 I3 issues
Post by jrbe »
NE555 wrote: Sat Nov 22, 2025 4:02 pm ... But the car will not move , IMMO is activated I believe with an error.
You may get better help on a BMW forum. Ze Germans immobilizers can be a pain to work through.
This thread seems to have similar struggles, https://openinverter.org/forum/viewtopic.php?t=5064
NE555
Post by NE555 »
I actually came from a bmw forum and on these forums it is difficult to weed through the ‘charge/change out the 12v battery’ posts and reply to numeous 12v battery replies without offending anyone who doesn’t read the last 20 thread messages mentioning 12v battery.
So I’m honestly hoping to get better suggestions here.
eee291
Has thanked: 13 times
Post by eee291 »
You may get better responses from forums that use expensive tools to hack this kinda stuff. Like MHA auto and similar ones. I wouldn't expect the solution to be cheap though.
This issue sounds similar to VW's component Security. Where if you swap something something simple like the comfort module that regulates windows and whatnot you will not be able to extract the pin code required to learn a new key because they split the key and put a part in the cluster another somewhere else etc.
If that is the case for you then you only have a few options left like a BMW dealer or immo delete. I've not really seen many or any real immo bypass or deletes for EVs though. 🤷‍♂️
NE555
Post by NE555 »
As it appears now the issue lies with the eDME
golfdubcrazy
Been thanked: 11 times
Post by golfdubcrazy »
by the sounds of it, the inverter on the motor probably had issues in the past and the quick and lazy way was to swap the inverter and BDC from a working car to keep the immo data matched.
when you reprogrammed it you changed that to the data of the original car on the BDC which does not match the inverter and you will have to reprogram the immo on the inverter to match.
good luck
