Free spinning a motor (a lot) without cooling
Scrappyjoe
Has thanked: 55 times
Been thanked: 32 times
Post by Scrappyjoe »
Hello,
I'm midway through a hybrid camper conversion project, and one diff has an outlander rear motor on it, and the other has the original petrol engine. The outlander rear motor turns when the wheels turn, but it is not hooked up to an inverter or cooling lines.
December is coming, and we are planning a long (200km+) camping trip. Is it safe to just plug the coolant holes and drive for such a long time, or do I need to implement cooling (pipes + radiator + water pump) before we go? There will be no load to speak of on the electric motor, but the diff and motor will be spinning at highway speeds for several hours at a time.
Has thanked: 330 times
Been thanked: 848 times
Re: Free spinning a motor (a lot) without cooling
This is fine. Motor can freewheel.
Just do not join any of the phase leads.
Make sure to plug all holes not to get an debris or moisture in there.
Scrappyjoe
Thanks Tom. Yes, that’s the plan - seal all holes well and isolate the phase wires with multiple layers of insulation and then wrap it all in thick plastic and cable tie to the underbody. It’s a high vehicle so it should be fine.
