EM57 Resolver connection, need help
Razor8
Has thanked: 9 times
Post by Razor8 »
Hello, friends!
I'm going to install an Nissan EM57 AZEO motor om my boat.
I cant get valid connection of resolver to Open Inverter board.
8 pins of resolver -R1,R2,S1,S2,S3,S4 temp1, Temp2.
on the board I have 4pins + 2 temp pins
temp+, temp-, to temp1, temp 2 on board, here is clear
R1 resolver pin to ENC_IN_Z/RES_R1
S2 resolver pin to ENC_IN_A/RES_S2
S3 resolver pin to ENC_IN_B/RES_S3
R2 resolver pin to? nowhere? to GND?
S1 and S4 conected together and to ENC_5V/RES_S4S1, Should I also add 5dc volts here?
Razor8
Re: EM57 Resolver connection, need help
Post by Razor8 »
some information:
S4 and S1 connect to GND?
what about R2 pin from resolver?
should I connect 5v dc to resolver?
Razor8
Post by Razor8 »
Its seems to me - R2 must be connected to GND
manny
Has thanked: 58 times
Been thanked: 159 times
Post by manny »
Yes. Resolver excitation signal is connected to GND and R1.
S1 and S4 connect to RES_S4S1 pin, the OI board should have 1.5V on this pin
  • PSA battery (50kWh)
  • Zombie VCU
Razor8
Post by Razor8 »
manny wrote: Fri Oct 17, 2025 10:39 am Yes. Resolver excitation signal is connected to GND and R1.
Thank you!
Get connected.
R2 resolver pin to GND
S1 and S4 resolver pin to RES_S1S4
checked the voltage on S1S4 - 1.52 volt
I turn on the board's power supply...
blinking led lamp on - OUT_precherge
and always on - OUT-Error....
HV DC - 300 volts
push IN_Start - starts to burn constantly OUT_DCSW and a quiet squeaking sound of work can be heard
in WEB Interface I can stop Inverter - and the sound disappears
if I press- show last errors - only CANTIMEOUT
pressing the throttle handle does nothing. check thtottle voltage - from 0.8 v to 4v
Error led always ON
If disconnect HV DC - than I cant start Inverter by pressing button
Please give me any ideas. How can I fix this error?
Zieg
Has thanked: 168 times
Been thanked: 160 times
Post by Zieg »
Did you calibrate the throttle? Also just checking but you did put either the drive or reverse input high, right?
Razor8
Post by Razor8 »
Zieg wrote: Sat Oct 18, 2025 12:44 am Did you calibrate the throttle? Also just checking but you did put either the drive or reverse input high, right?
No, I do not calibrate the throttle. How can I do it?
IN_FWD connected to 12V
IN_REV is disconected
IN_REV and IN_FWD connected to switch which switches one of them to 12 volts.
Razor8
Post by Razor8 »
Calibrating throttle - its potmin, potmax parametrs?
potmin - 950
potmax - 4095
when inverter not started, display memory errors give- - NO errors, bat error led is on
when inverter is started, display memory errors give - CANTIMEOUT 4 times
why error led(OUT_ERR) is always on?
why I cant start the motor?
when I start the inverter - can hear a quiet PWM sound, when stops - the sound is disappear.
Razor8
Post by Razor8 »
when inverter starts and IN_FWD gets _12V - can hear a pulsating quiet sound
disconecting IN_FWD - sound stops.
motor not spining
How can I check the polarity of HV DC?
is it correct?
Razor8
Post by Razor8 »
update -
OI - starts, NO ERRORS, OUT_ERR - is ok.
after switching FWD or REVERS - start pwm sound
pressing the thottle - sound increasing, The motor shaft twitches but does not rotate.
HVDC is rectified voltage 220, about 300V DC. Diode rectifier, fuses are of course present.
A friend advises changing the sine and cosine in resolver.
Please share your ideas
zippy500
Has thanked: 100 times
Been thanked: 7 times
Post by zippy500 »
this the drop in board OI board ?
Have you configed the syncoff ?
Razor8
Post by Razor8 »
zippy500 wrote: Sat Oct 18, 2025 1:30 pm this the drop in board OI board ?
No, I have not.
How can this be done?
Razor8
Post by Razor8 »
update:
No Errors, OpenInverter starts
select forward or reversr
then pressing throtlle
the motor shaft starts to jerk in different directions!?
resover problem?
manny
Post by manny »
  • Zombie VCU
Zieg
Post by Zieg »
Polarity on your dc in looks correct. If you hooked it up backwards you would have been.. immediately aware of it.
potmax being 4095 says to me something is wrong with your circuit and you may need to add a resistor in series to the signal. Though I'm not sure if that would cause this issue? As Manny said read those links, and post your parameters too.
Razor8
Post by Razor8 »
It looks like the problem is only in the resolver.
I triple checked the connection - connection is absolutly correct.
checked the resistance of the windings
R1-R2 -11.9
S1S3 - 27
S2S4- 27.5
I'll try to adjust some parameters.
When turning the shaft manually - value of a variable ANGLE changes randomly
Did you ever check for the excitation sine wave on R1?
Also read forum rules on how to ask for support (param file missing)
Razor8
Post by Razor8 »
johu wrote: Sun Oct 19, 2025 1:32 pm Did you ever check for the excitation sine wave on R1?
No, I haven't checked the signal shape yet, I'm waiting for an oscilloscope.
EVGO1987
Post by EVGO1987 »
From my experience, you shouldn't trust the resolver signal names, and try some different combinations.
Because even if you look up some drawings of resolvers, you will see different schemes from different sources.
Based on the resistance measurements you know, which coil is which (1x excitation coil, 2x reflection coils).. and then, it is a bit trial and error with a new resolver. Once you will find the right combination / wire order, it is then a known combination which can be replicated.
Besides, there should be kind of settings for the resolver, like pole-pair count and transformation ratio.
Motor jerking, from my experience, is wrong combination of the wires... because then, for example, you have the excitation right, sine-reflection right, but cosine reflection reversed, which means 180 dg phase offset.. And that can't work.
WARNING!!!
Please, setup a low (!) speed limit / safety shut off while playing with angle sensor settings.
If the offset, which you have to set up, is 120-180 dg wrong, the motor will "run away".
Razor8
Post by Razor8 »
EVGO1987 wrote: Sun Oct 19, 2025 8:07 pm From my experience, you shouldn't trust the resolver signal names, and try some different combinations.
WARNING!!!
Thanks a lot.
I identified the excitation winding.
I checked the signal with an oscilloscope.
There was a sine wave on the excitation winding, 4.31 kHz. Vmax- 0.44v
The sin and cos windings have a lower amplitude sine wave, and the amplitude changes smoothly as the motor shaft rotates.
Vmax 0.14v
I believe everything is working correctly here.
Razor8
Post by Razor8 »
UPDATE-
I swapped the sin and cos - physically swapped the S2 and S3 wires—now the engine accelerates clockwise, both in reverse and forward.
and I cant stop it.
The fuse trips, or I turn off the high-voltage power.
The engine itself doesn't stop.
Parametr PINSWAP sincos - did not give such an effect
manny
Post by manny »
Did you do a syncofs calibration procedure?
Razor8 wrote: Mon Oct 20, 2025 2:19 pm I checked the signal with an oscilloscope.
Vmax 0.14v
0.44V and 0.14V seems low. But if the OI board does not give a loreamp error the signal is probably fine. Measurement error?
  • Zombie VCU
Razor8
Post by Razor8 »
manny wrote: Mon Oct 20, 2025 7:56 pm Did you do a syncofs calibration procedure?
Today I finished watching the tutorial video, I'll be adjusting the parameter tomorrow.
In OI board is NO Errors, mabe osciliscoope give a wrong scale
cant find a "syncosofs" for Nissan EM57, How can I get it?
manny
Post by manny »
You need to find this yourself
https://openinverter.org/wiki/Using_FOC_Software
Tuning Process:
Start inverter -> start input or "manualrun" on web interface. Select forward direction.
Observe value "angle" and turn rotor by hand -> you should see angle changes between 0 to 360°. If not, check resolver connection and excitation signal.
Start with syncofs=0
enter a positive value for "manualid". Start low, with respect to motor rating. E.g. 5% of rated current
Keep increasing the value until you notice that the motor starts to spin - make sure you hear PWM going
If motor spins, change syncofs in 1000 digit increments until it stops spinning. If you need to go below 0, like -1000 enter 64536 (=65536-1000)
If manualid is less than about max_motor_current/2 go back to 4. When approaching rated_motor_current/2 make your increments/decrements smaller, like down to 300 digits
You have found 1 of 2 possible offsets. Now you can enter a small value for "manualiq" and set "manualid" to 0.1, the motor should spin smooth in both directions
If it behaves differently in forward and reverse, add 32768 to syncofs. If the resulting value is > 65535, subtract 32768 instead (or do modulo addition in the first place)
  • Zombie VCU
Razor8
Post by Razor8 »
manny wrote: Tue Oct 21, 2025 7:17 am You need to find this yourself
Tuning Process:
I understood how the offset is configured. about SINCOFS.
but I couldn't find any information about SINCOSOFS. Mid point of sin/cos chip.
Do I need to adjust this midpoint?
