Testing Jeep Wrangler 4xe P1 Motor-Generator (LG HV “Alternator”) with OpenInverter
Posted: Thu Sep 04, 2025 8:26 pm
Hi everyone,
I’m starting a project to run the Jeep Wrangler 4xe (2021–2023) P1 belt-driven motor-generator using OpenInverter. This unit is interesting because it is relatively affordable and widely available in the US junkyards, yet it offers decent power and voltage levels compared to the usual HSGs.
What I know so far:
Officially called “Electric Motor / Alternator” by Mopar.
Part numbers: base 05190161 (suffixes AI, AJ, AK, AL, AM depending on revision/year).
Supplier: LG (logo visible on the nameplate → LG Energy Solution / LG Magna e-Powertrain).
Specs (from Jeep 4xe technical docs and nameplate):
Peak power: ~33 kW (≈44 hp)
Peak torque: ~53 Nm
Max speed: ~18 000 rpm
Nominal DC bus: ~355 V (Jeep’s HV pack runs 260–400 V)
3-phase output + liquid cooling + LV connector for resolver/NTC
Used as the P1 machine in the 4xe system (belted to the ICE crankshaft).
Why I think it’s interesting:
Much more powerful than the usual Hyundai/Kia HSG (~8–10 kW) or BMW i8 HSG (~15 kW).
Compact “alternator-style” package, liquid cooled, easy to mount via belt.
Appears regularly on eBay and Mopar parts stores at reasonable cost.
What I’d like help with:
Pinout of the LV connector (resolver and temperature sensor).
Any data on winding resistance/inductance or measured back-EMF constant (Ke).
Best inverter choice: I’m considering a Prius Gen 3 inverter with boost to drive this motor.
Expected electrical frequency at 18k rpm (depends on pole pairs, which I haven’t measured yet).
My idea is to use one of these machines to drive a centrifugal supercharger (for fun). For that I need to know if OpenInverter can handle it reliably and if anyone has already tried working with this Jeep unit.
Any information, tests, or tips would be highly appreciated!
I will receive soon the motor soon.
Thanks in advance.
What I know so far:
Peak torque: ~53 Nm
Thanks in advance.
