Zombieverter with Outlander
Posted: Tue Aug 26, 2025 8:20 am
Hello
I have drawn a draft wiring of zombieverter witn outlander componants, I would appreciate if anyone can confirm specifically the below and maybe overall, any mistakes in my understanding? Some questions maybe dumb to some so please forgive me.
Outlander DCDC OBC:
1- the DC sense is connected to temrinal 15 (key is on)
2- DC enable is connected to Zombieverter (via a relay) main contactor (I'm using SBOX for HV switching)
3- IGCT is connected to Zombieverter (via a relay) inverter power LS switch (pin 32)
4- CP is connected to charge port cp (j1772)
5- DCDC output to battery (do I need a fuse or fusible link here?)
6- configuration for charegr on Zombieverter is (out_lander), i read before there was an issue with this but can't confirm if its now fixed.
Outlander rear inverter:
1- IGCT to termimal 15 (key is on)
2- coms to motor is OEM
3- RSDN to gnd
Charge port:
1- CP to OBC as above
2- PP to Zombieverter pin 9 analog 1 read (and configure the threshold in Zombieverter gui for charge on)
Simpbms:
1- 12 volt direct from battery (via a fuse of course)
I didn't add fuses to the drawing and I'm sure the drawing could be clearer
Any suggestions on this overall is much appreciated. Thank you!
Outlander DCDC OBC:
3- RSDN to gnd
Charge port:
Simpbms:
