Gs450h oil pump disassembly issues
Posted: Thu Aug 21, 2025 8:11 am
by 0tik
Mine has literal phillips screws made out of aluminium clay. Obviously impossible to unscrew to change the bearings. Sorry, but i forgot to take a photo of it. I thought there was supposed to be torx screws. Is anyone else on the same boat as me and have figured out how to unscrew them? Metal is so soft that I am 100% sure that filling the head for flat-head screwdriver is going to end up with the head being fully ripped off.
Re: Gs450h oil pump disassembly issues
Posted: Thu Aug 21, 2025 8:22 am
by Bigpie
Mine was the same, I had to drill them out, and helicoil one. I did a rubbish video about it
Posted: Thu Aug 21, 2025 2:24 pm
by jrbe
Try Kroil soaking it for a day or 2. Transmission fluid with acetone is similar.
A few hits on the head may help shock it.
There are impact drivers that rotate the screw from a hammer hit, helps bite in while turning.
The body aluminum? you could try to freeze it first, aluminum will shrink more than the steel bolt letting off some tension.
Posted: Wed Mar 25, 2026 10:35 am
by abdurr681
0tik wrote: Thu Aug 21, 2025 8:11 am Mine has literal phillips screws made out of aluminium clay. Obviously impossible to unscrew to change the bearings. Sorry, but i forgot to take a photo of it. I thought there was supposed to be torx screws. Is anyone else on the same boat as me and have figured out how to unscrew them? Metal is so soft that I am 100% sure that filling the head for flat-head screwdriver is going to end up with the head being fully ripped off.
Hi mate, I have the exact same problem, and my gasket and pump looks exactly like yours, did you have a workaround the problem?
And did you need to replace the bearings in the end?
Posted: Wed Mar 25, 2026 10:59 pm
by jrbe
Anyone soak it with kroil and try? Freeze it then try?
