2013 Chevy Volt Gen1 battery relay module sensors
Posted: Fri Aug 08, 2025 4:16 pm
Hello,
I've been trying to find more info on the two (in/out) coolant sensors located at the front module of the battery pack, the one that houses the relays and the heater coil, as these sensors the same as the ones inside the battery? same temperature vs resistor value table? The 2012 service manual does not specifically list a clear table for these two sensors. Appreciate if someone can share any data.
Thanks.
Thanks.
