Telsa SDU and VW Beetle question
MoonUnit
Has thanked: 33 times
Been thanked: 14 times
Post by MoonUnit »
Hi, I am considering upgrading my Beetle from a Hyper 9 setup to direct drive using a Tesla SDU with a drop-in board.
My questions are, if anyone is running this setup:
What voltage range you are running it at, and
What battery physical configuration have you used (capacity, module choice, cooling etc.)?
I'm in the UK so no chassis-chopping allowed - batteries would have to fit in boxes in the frunk and behind the rear seat. If I do this upgrade, I intend to add DC charging and the position of the required header tank for cooling is a potential concern, hence the question around how you may have configured your batteries.
Thanks in advance.
modellfan
Has thanked: 20 times
Been thanked: 61 times
Re: Telsa SDU and VW Beetle question
Post by modellfan »
Not sure how your questions answer your problem. You can run any battery with an SDU as long as the voltage is not above the upper limit you can google . 96s is save. Lower limit is basically not given by sdu but by charger and other components .
I am running 7 out of 8 bmw i3 modules with 94 ah with an idc to 350A limited sdu
Has thanked: 246 times
Been thanked: 469 times
Power output will be somewhat proportional to voltage. Ideally 350-400v. BMW phev packs, or really most hybrid packs are a good choice. They have the stiffness to handle the power of a Tesla drive unit. They generally have higher c rated cells, and will handle dc fast charging. And would be compact enough to fit in a beetle giving your 15-25kwh. And wouldn’t cost an arm and a leg
MoonUnit
Post by MoonUnit »
Thanks. Project is inching forward. Are you selling the driveshaft adapters for Tesla SDU to Beetle yet?
