Using Zombie with Leaf Inverter
Posted: Mon Jul 07, 2025 2:04 am
by raisinscry
I'm running a Gen 2 Leaf motor and inverter setup, controlled by a Zombie. Does the Leaf inverter already measure current internally, or do I still need to add an IVT-S shunt?
Re: Using Zombie with Leaf Inverter
Posted: Mon Jul 07, 2025 6:33 am
by GregFordyce
From firmware 2.20 you no longer need the IVT-S shunt.
Posted: Mon Jul 07, 2025 8:35 am
GregFordyce wrote: Mon Jul 07, 2025 6:33 am From firmware 2.20 you no longer need the IVT-S shunt.
Not correct.
raisinscry wrote: Mon Jul 07, 2025 2:04 am Does the Leaf inverter already measure current internally
It does not measure current, it only measures voltage, you do not need the IVT-s to do precharge. So you can run the leaf stack without an IVT-s but you would not be able to measure the current draw only the inverter input voltage.
Posted: Mon Jul 07, 2025 11:40 am
Maybe Greg was referring to Leaf BMS support?
Posted: Mon Jul 07, 2025 9:18 pm
by GregFordyce
Thanks for putting me straight, I'm still getting my head round the ZV. 😬 I was confusing the Leaf BMS support with the inverter functionality.
