I am about to drive this Megane and i still have those pesky "Engine warning" messages together with "Battery charging" message.
I fiddled with some connectors inside the protection - relay module under the bonnet and i see if i disconnect CAN connector the car actually reacts to CAN connector removal.
viewtopic.php?p=82157#p82157
Does anyone have or know about where to get some CAN logs for communication from ECU to Dash control unit?
Tnx
Renault Megane III 1.6 16V CAN logs
- Has thanked: 148 times
- Been thanked: 370 times
Re: Renault Megane III 1.6 16V CAN logs
I found another Megane III 1.6 16V year 2010 owner who was kind enough to allow me to record some logs from OBDII port. I recorded from engine still with door open to engine starting and stabilizing at idle and after some seconds i applčied throttle to spool the engine up. Then i stopped and recorded second file again, engine at idle. Resulting files are here...
For the CSV files i used Savyycan and M2 Macchina device. I didnt have time for more in-depth testing for various inputs, such as throttle or brake inputs.
The other is txt file i made using my own CAN logger.
Feel free to use them, just provide feedback if you find some DBCs
- Megane Alive2.csv
- (2.02 MiB) Downloaded 27 times
- Megane Alive.txt
- (557.28 KiB) Downloaded 27 times
- Megane Alive.csv
- (3.77 MiB) Downloaded 24 times
