Nissan Leaf park actuator motor and SRM motor control
Posted: Tue Jun 17, 2025 7:54 am
by J0hannes
In case someone wonders what this is made of, I happened to open one "accidentally"
If you remove the srcews which hold the actuator on the sheetmetal part, the motor splits.
This is SO COOL!!!
There is a Cycloid gear drive in this
Two SOT-23 hall sensors I0F scribed on packaging --> Could this be TI DRV5023?
Two SOT-223 502A 5394 82 --> Voltage regulators for hall sensors?
Re: Nissan Leaf park actuator motor
Posted: Sat Jun 21, 2025 9:08 pm
by PaulHeystee
Hi, Just for your information; I have a developed a controller for these park motors, based on Adafruit CAN Feather or Rapsberry PR2040 Zero. It can be controlled by CAN (feather board only) or analogue (switch)
If anybody is interested please send me a DM
Posted: Sun Jul 06, 2025 7:32 am
by GregFordyce
Over on this forum user dddrewski has posted his park pawl implementation using a Cloudray 3-Phase Stepper Motor Driver 3DM580S driven by an Arduino Nano. It's not complete but there's enough there to get started.
Here's the wiring diagram as built, and the arduino nano program to run the transmission park pawl motor.
The first time it runs, the park indicator light flashes. You push the park button and it will do a homing routine to move to park, and remember the position.
The arduino stays powered all the time, so it remembers to state of the park pawl after that.
I there are a couple of voltage dividers in there that I didn't write down the resistor values. I don't remember, but they're probably in the 100k ohm range. They result in the nano only seeing 5V on inputs.
I also didn't write down the resistor value on the LED output. It was a 3V LED, so I just tried a few values until it read 3V across the LED.
The only thing I may change is to put the Resolve-EV controller into Neutral when park is activated. Right now, it will go into park while the Resolve-EV is in Drive or Reverse.
//arduino program written for the nano
//this program is to control the park pawl motor on a nissan leaf transmission
#include <Encoder.h>
// IO
const int encA = 2;
const int encB = 3;
const int driveEnable = 4;
const int driveDir = 5;
const int drivePulse = 6;
const int senseIgnition = 7;
const int senseBrake = 8;
const int buttonsRND = 10;
const int buttonP = 11;
const int parkIndicator = 12;
// Other constants
const int posDrive = 0; // in encoder counts
const int posPark = -450;
const float PulsePerCount = 2.661290323; //encoder counts divided by drive pusles
const int posError = 5; //number of counts of the encoder that it can vary without causing an error. Also used for the power up routine to find the end of travel.
const int pulseWidth = 1; //in miliseconds for the stepper drive pulse width
const int pulsesPerErrorCheck = 10;
const int inPark = 1;
const int inDrive = 2;
int pawlState = 0;
Encoder pawlEncoder(encA, encB);
void setup() {
// put your setup code here, to run once:
Serial.begin(115200);
// IO Pin Assignments
pinMode(driveEnable,OUTPUT);
pinMode(driveDir,OUTPUT);
pinMode(drivePulse,OUTPUT);
pinMode(buttonsRND,INPUT_PULLUP);
pinMode(buttonP,INPUT_PULLUP);
pinMode(senseBrake,INPUT);
pinMode(senseIgnition,INPUT);
pinMode(parkIndicator,OUTPUT);
digitalWrite(driveEnable,HIGH); // disable current to the motor
// On power up, assume unknown position. Flash park button until pressed and do homing
while(!(!digitalRead(buttonP) && digitalRead(senseBrake) && digitalRead(senseIgnition))){
digitalWrite(parkIndicator, HIGH);
delay(200); // delay for park indicator to flash on and off showing it needs to be pressed
digitalWrite(parkIndicator, LOW);
delay(200);
// wait for button release
while(!digitalRead(buttonP)){}
// move to park until a following error is detected (hard stop)
pawlEncoder.write(0);
movePawl(posPark);
delay(2000); // if pressed up against the hard stop, let mechanism relax before zeroing the encoder
pawlEncoder.write(posPark);
pawlState = inPark;
void loop() {
// put your main code here, to run repeatedly:
// check if the following is true: RND pressed, brake pressed and ignition on -> go to drive position
if(digitalRead(buttonsRND) && digitalRead(senseBrake) && digitalRead(senseIgnition) && (pawlState == inPark)){
movePawl(posDrive);
pawlState = inDrive;
// check if the following is true: P pressed, brake pressed and ignition on -> go to park position
if(!digitalRead(buttonP) && digitalRead(senseBrake) && digitalRead(senseIgnition) && (pawlState == inDrive)){
movePawl(posPark);
pawlState = inPark;
// set the state to the correct state while the ignition is on
if(digitalRead(senseIgnition) && (pawlState == inPark)){digitalWrite(parkIndicator, HIGH);}
else{digitalWrite(parkIndicator, LOW);}
int indexA;
int indexB;
long startposition;
int direction;
int errorstate;
void movePawl(int targetposition){
// get the motor ready to run
digitalWrite(driveEnable,LOW);
delay(100); // wait for drive enable to take effect
startposition = pawlEncoder.read();
errorstate = LOW;
// set the motor direction
if (targetposition < startposition){
direction = -1;
digitalWrite(driveDir, LOW);
delay(5); // delay per timing chart for drive on control signal changes
else {
direction = 1;
digitalWrite(driveDir, HIGH);
// move the motor until target position is reached, or position error is detected
indexA = 0;
while (!errorstate && !checkInposition(targetposition,direction)){
indexB = 0;
while (indexB < pulsesPerErrorCheck){
digitalWrite(drivePulse, HIGH);
delay(pulseWidth);
digitalWrite(drivePulse, LOW);
delay(pulseWidth);
indexB ++;
indexA ++;
// check the current position against the expected position
if ( abs(startposition + direction*indexA*indexB/PulsePerCount - pawlEncoder.read()) > posError){
errorstate = HIGH;
digitalWrite(driveEnable,HIGH); // move done, disable current to motor
int checkInposition(int targ, int dir){
if(dir==1){
return(pawlEncoder.read() > targ);
else{
return(pawlEncoder.read() < targ);
Posted: Thu Jul 17, 2025 11:58 am
by PaulHeystee
This looked like a viable solution, however, I was not able to get it working, hence the design of my own controller.
Mine is also less bulky and it does not require 24 volts to run it.
Posted: Fri Aug 29, 2025 6:12 am
by J0hannes
My father got curious about the park actuator motor and is working on motor control, this'll probably become some sort of controller which would be open source.
He pieced together the connector pinmap and wiring diagram, so it's now useful
Schematic of the motor FPCB
Hall sensors are TDK Mikronas HAL502 type
10F SOT-23 type not identified, but he's most certain that it's a double protection diode
Motor first spins, just feed forward
After few nightshifts, the motor dyno gives approx 7kg on a 161mm lever, so that's approx 11Nm already!
Currently running feed forward.
PaulHeystee wrote: ↑Thu Jul 17, 2025 11:58 am
Have you implemented the encoder feedback in your controller or are you running feed forward? Would you be willing to share details?
Posted: Fri Aug 29, 2025 11:32 am
by jrbe
Is there any current sense in the circuit? Could maybe be used in place of or as backup to the encoder feedback. Might be in the nice to have pile though, likely unnecessary. I was thinking Trinamic end stop sense style.
Posted: Sun Sep 07, 2025 7:14 am
by J0hannes
More information from research dept.
Almost certain that the SOT-23 is a 10F diode
Also, Renesas is Japanese manufacturer, so that would also make sense.
Some observations:
It's 155 encoder A or B pulses from end to end
Angular movement is approx 30 degrees
Motor resistance 1,35ohm / phase
Phase inductance varies between about 1,6mH to 4,4mH depending on rotor position
phase coil saturation. On pole ~4ms, between poles ~1ms
Now the test code has been improved, so the actuator doesn't change direction when it hits a hard stop and misses steps.
Testing with park pawl and input gear
Powerstage
In the video, you hear first disengage and then engagement of the park pawl. As the tooth is not aligned with the pawl, you can totate the gears until the pawl engages by spring force.
HW and SW for park actuator controller
Posted: Wed Mar 18, 2026 7:24 pm
by J0hannes
The SRM contoller is now available for anyone who wants to make one for themselves
Hardware has the following:
Arduino nano is used as controller
Three configurable control inputs, meaning they can be used switching high or switching low depending on your application
Two inputs for hall encoder
Two configurable outputs for relay / lamp / led
Output for three phase SRM motor (the design is tested with Leaf park actuator motor)
Power supply for motor power can be shared with the controller, or they can be separated if you desire
Motor power supply protected by polyfuse
Hardware files:
All hardware files are offered AS IS.
SRM_gerber.zip made with original design on Pads. PCB can be ordered with this
SRM_KiCad_designfiles.zip contains KiCad design files. They were converted from old Pads design. Files were opened first with newer Pads VX and then exported and saved to Altium project, which was then imported to KiCad. So be aware that there may be some discrepancies of bugs of any sorts. On a quick overview things look like they should.
Software V 1.0 with the following functionality:
SRM motor control with encoder feedback
Safety functionality, brake pedal must be pressed before park lock operates
Serial communication for functionality and fault feedback
Fault detection forward and reverse direction (over/under travel and stall)
