I'm working on designing a battery box with Taycan modules. The shape of the box from the side looks like an inverted L. In order to minimize parts, I would like to place modules on both sides of a cooling plate. This would require modules 1 & 2 to be right side up, modules 3 & 4 to be upside down and modules 5 - 8 to be on their long sides. Conventional wisdom on the forum suggests that one should not put modules 4 & 5 upside down, but there are exceptions. Does anyone have any experience or knowledge with Taycan that can confirm is it ok to use them upside down? Or do I need to turn them right side up and add another cooling plate underneath them? Please see the attachment for a drawing. I'm having trouble adding it to the text.
Battery Box Layout For Taycan Modules
- Has thanked: 330 times
- Been thanked: 847 times
Re: Battery Box Layout For Taycan Modules
Taycan modules are pouches so can be position how you want.
