Motor Judders in drive
Posted: Sat May 17, 2025 7:44 pm
by manj3000
Hi all i have a leaf gen2 stack with leaf throttle running on the zombieinverter, i calibrated the throttle and everything powers up ok.
When i run the system in reverse everything is nice and smooth but lacking a little torque but when i switch it to drive the motor judders without straight away without touching the throttle, when you press the throttle it spins up but then starts fluctuating. when you let the throttle off it starts juddering again.
Any help would be great
I would put up parameters file but i don't know how to
Re: Motor Judders in drive
Posted: Sat May 17, 2025 10:24 pm
by LRBen
Sounds like you have it running on the bench? It will act like that when it's unloaded.
Posted: Sun May 18, 2025 8:02 am
by manj3000
Hi its installed in the vehicle and it does the same, we have not tried it in gear yet but will do on Monday and see what happens
Parameters attached
params (1).json
(1.96 KiB) Downloaded 56 times
Posted: Sun May 18, 2025 7:31 pm
by LRBen
I would set regen to 0 for now. Then add it in slowly when it's driving to suit your tastes along with regen ramp which looks too high for now as well.
Also change throtramp to 5.
Posted: Tue May 20, 2025 9:53 am
by Rustybkts
The latest firmware release v2.22a has a weak reverse which I assume will be fixed on the next one.
Beware of throtramprpm and leave it set to 20,000 as any rpm over a lower setting allows full power uncontrolled acceleration as I found when setting it to 1000.
Seriously scary!
Posted: Tue May 20, 2025 11:47 am
Rustybkts wrote: Tue May 20, 2025 9:53 am The latest firmware release v2.22a has a weak reverse
All releases have this. Not just this one, it wil be solved in the future.
Posted: Fri May 23, 2025 7:05 pm
by manj3000
Thanks for all the info got it working ok and got around the reverse for now
Posted: Sat May 24, 2025 8:25 am
by Jacobsmess
What was the issue?
