Lin heater logs from e2008
Posted: Fri May 16, 2025 3:31 pm
by GeneralScanner
I have some Lin logs from my missus's e2008
From the heater and I believe a/c Lin bus this runs a 5kw eberspacher heater.
I started the log full hot I believe then full cold then full hot again. I did verify the heater hose were getting warm.
https://github.com/Gn1c3/Lin-E2008-Heater-a-c/tree/main
Re: Lin heater logs from e2008
Posted: Fri May 16, 2025 3:39 pm
Posted: Fri May 16, 2025 3:53 pm
by GeneralScanner
Yep
Posted: Sat May 17, 2025 5:07 am
by Landsi
Cool! You wouldn’t happen to have come accross a pinout of these, would you? I have tried and failed to find one in the past…
Posted: Sat May 17, 2025 9:46 am
by GeneralScanner
Posted: Sat May 17, 2025 9:52 am
by GeneralScanner
4F0973703
Also available as a pigtail for those who don't trust their own crimping ability
Posted: Sat May 17, 2025 10:54 am
by Landsi
Brilliant! Very thanks, much clap
Posted: Sat May 17, 2025 12:08 pm
Can you post raw salae log on github so it can be exported in a different format
Posted: Sat May 17, 2025 1:36 pm
by GeneralScanner
Posted: Sat May 17, 2025 1:43 pm
Posted: Sun May 18, 2025 8:46 pm
by GeneralScanner
Posted: Sun May 18, 2025 9:55 pm
What is the other component on the same network? AC compressor or a pump?
Posted: Mon May 19, 2025 12:39 pm
by GeneralScanner
8020 is the a/c compressor
Posted: Mon May 19, 2025 12:41 pm
by GeneralScanner
1775 is the "electric drive train supervisor ECU".
Posted: Tue May 20, 2025 2:15 pm
Can you please get some logs of it running steady just heating.
Then a log of going from HVAC on to off.
Posted: Tue May 20, 2025 2:32 pm
Small issue to gum up the works, it has a heatpump setup so using the AC compressor to heat the cabin. We will need to figure out how to force it to do ptc heating.
https://ev-database.org/uk/car/1947/Peu ... 008-54-kWh
Heat pump (HP) Yes
HP Standard Equipment Yes
Posted: Tue May 20, 2025 3:48 pm
by GeneralScanner
There wasn't a pid in diagnostic data for heater.
There wasn't a diagnostic activation for the heater.
How about if I unplug the compressor.
Was that 'heat pump yes' from my data?
Posted: Tue May 20, 2025 3:50 pm
by GeneralScanner
Could try charging.......it's a battery heater in principle..... although heater hoses come right off it
Posted: Tue May 20, 2025 4:03 pm
by GeneralScanner
Yeah if I unplug the compressor and the coolant still gets hot then it has to be the heater.
Posted: Tue May 20, 2025 4:15 pm
GeneralScanner wrote: ↑Tue May 20, 2025 4:03 pm
That is the quickest test. Also good to easily identify the LIN ids for the AC compressor
The yes heat pump is from reading up on the e-2008 specs
Posted: Thu May 22, 2025 2:48 pm
Got it working it tries drawing current and pulls down my HV power supply. Now its time to do testing on a real setup (I do not have one).
Lin bus info below
https://github.com/Tom-evnut/Lin-E2008-Heater-a-c
Posted: Thu May 29, 2025 8:09 am
by AMP3R
Hey, can you make logs from lin of steering wheel? I want to turn on the lights in buttons.
Posted: Thu May 29, 2025 1:13 pm
by GeneralScanner
My HV wiring just rocked up.
Part number 4-2103177-1 for the housing.
A TE HVA 280 apparently.
Stellantis part number is 9826145080 and has two of these connectors on either end of a pair of cables. The hvil appears to be internal to the plug (can't see any external LV wiring) .
Back of plug to back of plug is 30cm
Posted: Thu May 29, 2025 2:41 pm
It also is a nice and readily available connector which is a bonus.
https://www.te.com/en/product-4-2103177-1.html
Note this is just the housing not a full set with crimps, backshell and seals.
