Awd SUV conversion
Posted: Mon May 05, 2025 10:44 pm
Hello All,
I am in early stages of creating a conversion for a 2002 Suzuki XL7 SUV and I want to use leaf motors.
I have a 2011 Nissan leaf in working order except the replacement battery is now at 10/12 bars. My plan is to source at least one more gen 1 and set up the two motors one for fwd and one for rwd, combine the battery packs and put it all on a test bench jig mirroring the frame of the Suzuki.
I am also enamored with the idea of a quad motor setup for tank turns and related tomfoolery. Is there something that can control 2 and 4 motors to be flexible as to what I do. It always depends on how far the money stretches.
My weak sauce alternative is to make the Suzuki rwd only with the Gen 1 leaf and setup the original engine and fwd bits as a range extender. In that case I should have all I need.
Your ideas and wisdom are in need. What do you think?
