change from key start to button start
Posted: Wed Mar 26, 2025 1:20 am
by medo
Hi, so on my BMW the start command (0x55) is missing when I turn the key to the crank position, possibly because of the missing engine control unit, how can I change this in the BMW_E65.cpp file so that I use a start button for it, I don't want it to go into Run mode immediately when the ignition is turned on
void BMW_E65::handle130(uint32_t data[2])
uint8_t* bytes = (uint8_t*)data;
if ((bytes[0] == 0x45) || (bytes[0] == 0x55))
// 0x45 is run, 0x55 is engine crank request
terminal15On = true;
else
terminal15On = false;
if ((bytes[0] & 0x01) > 0)
terminalROn = true;
else
terminalROn = false;
if ((bytes[0] & 0x04) > 0)
else
if ((bytes[0] & 0x10) > 0)
terminal50On = true;
else
terminal50On = false;
if ((bytes[2] & 0x08) > 0)
StartButt = true;
else
StartButt = false;
that should be in this code section
Re: change from key start to button start
Posted: Wed Mar 26, 2025 10:02 am
medo wrote: ↑Wed Mar 26, 2025 1:20 am
Why? you will end up draining your 12V battery.
Posted: Wed Mar 26, 2025 11:36 am
by medo
So, again, key in, nothing happens on the VCU, key position radio, nothing happens on the VCU, key position ignition T15, VCU goes immediately into run mode, that's exactly what I don't want, actually a 0x55 should be sent at crank position on CAN, but it doesn't, therefore a button for start signal
Posted: Wed Mar 26, 2025 12:29 pm
How do propose it to work for your case then? Not a standard bmw button over CAN?
You can change the code however you want. Just replace the CAN based signals with the digital ones from the Classic Vehicle class.
Posted: Wed Mar 26, 2025 12:43 pm
by medo
I have no idea why the CAN message 0x55 does not appear on the crank position, the message 0x45 appears on the ignition position, it is a BMW E60, identical to the E65, at least from the CAN messages
Posted: Wed Mar 26, 2025 1:11 pm
by jrbe
medo wrote: ↑Wed Mar 26, 2025 12:43 pm
Is there an immobilizer missing?
Posted: Wed Mar 26, 2025 1:16 pm
by medo
No, it's all original, I just removed the engine control unit, it was a diesel before
But it must also be programmed so that as soon as the ignition is on, it immediately goes into run mode
so T15 and start signal in one
Posted: Wed Mar 26, 2025 8:14 pm
by medo
I changed the code for testing, so that when the can message 0x45 comes to id130, T15 changes to on, but the LDU goes to run mode, something is wrong.
if (bytes[0] == 0x45)
else
Posted: Fri Apr 04, 2025 9:30 pm
by medo
Can anyone really help me modify the BMW_e65.cpp file so that I can use a classic key?
Unfortunately, I don't know much about programming.
Posted: Sat Apr 05, 2025 6:29 am
Huh if i think analog to my Pug VCU i need to send it "engine running signal" for it to go out of eco mode and start cabin power supply. For me this signal is coupled from two parts... Engine RPM at least 800rpm and positive signal on the alternator signal wire. Then internal BSI starts car operation.
Posted: Sat Apr 05, 2025 11:23 am
by medo
I finally managed to change Ready and Start to classic, it works so far, but I get a warning when compiling, what does that mean
src/hwinit.cpp: In function 'void clock_setup()':
src/hwinit.cpp:46:21: warning: 'void rcc_clock_setup_in_hse_8mhz_out_72mhz()' is deprecated: use rcc_clock_setup_pll(&rcc_hse_configs[RCC_CLOCK_HSE8_72MHZ]) [-Wdeprecated-declarations]
46 | RCC_CLOCK_SETUP();
In file included from libopencm3/include/libopencm3/stm32/rcc.h:26,
from src/hwinit.cpp:26:
libopencm3/include/libopencm3/stm32/f1/rcc.h:780:6: note: declared here
780 | void rcc_clock_setup_in_hse_8mhz_out_72mhz(void) LIBOPENCM3_DEPRECATED("use rcc_clock_setup_pll(&rcc_hse_configs[RCC_CLOCK_HSE8_72MHZ])");
Posted: Sat Jan 17, 2026 2:31 pm
by medo
I think I now understand why I don't see CAN message 0x55 when the VCU is in ignition mode, in order to start the inverter. Since the engine speed of 750 rpm is already programmed in when the ignition is switched on, BMW doesn't allow a start because it thinks the engine is already running. It would be smarter to only allow this speed after the inverter goes into run mode.
