Zombieverter 2.22A Release
Posted: Sun Mar 23, 2025 12:22 pm
https://github.com/damienmaguire/Stm32- ... /tag/2.22a
Please Note: when upgrading from earlier versions you must reselect your inverter type and save params. This is due to the inverter sequence numbering in the param database being updated in this version. Also as the hardware timer configurations have changed, a reboot/power cycle of the VCU must be done after software upgrade.
Lexus IS300h Inverter fix
LIN bus fix for VW coolant heater
Nissan leaf improvement for Gen3 PDM operation
Other small fixes.
Tested in all 4 currently running EVBMW vehicles and Gen3 Prius test bench. See parameter files for more info.
If you find any issues please report back here.
Other small fixes.
