Zombiverter VCU Charging Cut-Off Guidance
Posted: Tue Mar 11, 2025 10:31 am
by maiks
Hello,
I have a Zombiverter VCU and a 3.6kW Leaf PDM that I am using to charge a battery pack. The battery is supposed to be 72kW when fully charged (400V * 180Ah) and 64kW at nominal voltage (355V * 180Ah). However, when charging with the EVSE set to 15A, I noticed that the current drops to around 1.5A once the voltage reaches 355V and does not increase beyond that. Could you help me understand what might be causing this issue? I have attached a copy of my parameters for your reference.
Re: Zombiverter VCU Charging Cut-Off Guidance
Posted: Tue Mar 11, 2025 11:55 am
Please provide a CAN log too.
Also what generation of Leaf PDM? What is the battery pack and BMS?
Posted: Tue Mar 11, 2025 12:05 pm
by maiks
tom91 wrote: ↑Tue Mar 11, 2025 11:55 am
gen 2 PDM, l connected 24 catl modules (4S1P, 180Ah,nominal voltage 14.8) and leaf BMS. Am going to log CAN later and l send
Posted: Tue Mar 11, 2025 1:52 pm
by Bratitude
maiks wrote: ↑Tue Mar 11, 2025 12:05 pm
If u disconnect the bms, will it keep charging? What size battery was the bms from?
Posted: Tue Mar 11, 2025 1:56 pm
You set "BMS_Mode": 0
Yet you have a Leaf BMS?
What firmware version are you on?
Posted: Tue Mar 11, 2025 3:25 pm
by maiks
Bratitude wrote: ↑Tue Mar 11, 2025 1:52 pm
I disconnected the bms. It was a 24kw bms but am planning to buy flying ADC bms
Posted: Tue Mar 11, 2025 3:28 pm
by maiks
tom91 wrote: ↑Tue Mar 11, 2025 1:56 pm
I disconnected the bms . Am using the latest firmware 2.20A
Posted: Thu Mar 13, 2025 8:10 pm
by maiks
I've finally figured out the problem—it was with the EVS. After replacing it, the charging works as expected
