deye inverter problem
Posted: Thu Mar 06, 2025 2:09 pm
Hi everyone, could someone help me with this issue? I installed a 30-panel solar system on-grid, with each panel rated at 585W. I also installed the Deye Sun-15K-G05 inverter and the Eastron SDM630MCT smart meter. The wiring is all correct, but the problem is that when I turn on the meter from the settings inverter, I get 0W from the production, even though there’s sunlight. However, when I turn off the meter, I can see how much energy the solar panels are generating. Is there any solution to this, or has anyone experienced this issue before? Thanks!"
