Reverse engineering the MQB Electric steering rack
Posted: Sat Feb 15, 2025 8:29 pm
I'm looking for a bit of direction in trying to hack this MQB rack from a VW Transporter 6.1.
It works in fail safe but it'd be nicer if it ran with the speed mapping to the level of assist.
I've got some Canlogs from a MK7 Golf (I think) and played them back. I've identified the differences between the two, and there seems to be only one CAN ID required to wake up the rack... 0x0FD ESP_21
When powered up the unit sends out comms on...
086 - 4th and 5th bits change with torque input on the rack, whilt playing the CAN log back at the rack these bits change moreso, 4th bit indicates direction of turn (9F turned CCW and DF/5F when turned CW)
09F - 6th bit changes with torque applied to the rack, I need to map this out but this appears to be the angle of the steering wheel
7th bit changes with direction also (00 for CW and 80 for CCW)
5FC - is a static message when in failsafe mode (no playback, with playback it responds), I need to look into this further but changes occur on the 1st, 2nd, 3rd and 4th bits
32A - need to check this one more but no changes obseved
6C0 - changes at 7th bit from 19 to 11 when having the log played back.
Any pointers on how to narrow things down further?
0FD in the CAN log appears to contain some speed information but I'm sure someone with more experience will be able to shed some some light.
I've cut the CAN log down into sections where it appears there is no driving and parts with driving, as expected, playing back with driving provides more assistance than playing back parts with driving.
