Precharge time
Posted: Tue Feb 04, 2025 6:18 pm
Hello,
I am converting an old Mini using the following parts:
- Outlander rear motor
- Outlander rear inverter
- Zombieverter V2.20A
- BMW 540e battery 12 kWh with S-Box
I have taken a big step forward now, vehicle is running and I could drive the first 100 meters or so. Really happy. But of course still a lot to do.
Now for my question:
If I got it right, precharge needs some time to charge the capacitors of the inverter, and if the voltage behind the precharge circuit reaches the given setting, the positive contactor pulls in and bypasses the resistor. In my case the precharge goes VERY fast, I'm uncertain if this is correct.
I turn the ignition on, UDC reads 332 V and UDC2 something around 0. Then I turn the key to the start position and UDC2 immediately goes up to 332 V. I can hear two clicks from the S-Box, but they're within a fraction of a second. I was recording UDC2, there's no ramp-up visible, the graph shows a step. Is this correct? I was expecting a much longer time for the process.
Thanks,
Stefan
Thanks,
Stefan
