Fully Labeled Pigtails/Harnesses for Tesla SDU & LDU for Sale
Posted: Mon Jan 06, 2025 8:56 pm
Hi everyone,
I wanted to make you aware of some harnesses I’ve been working on that might make your EV projects a bit easier. I’m now offering fully labeled pigtails/harnesses for both Tesla Small Drive Units (SDU) and Large Drive Units (LDU).
Cheers!
- Tesla SDU Harness: These 1-meter pigtails are labeled for Openinverter board pinouts with heat shrink tube labels, and the wires are color-coded for added convenience. I recently partnered with a manufacturer to produce these in bulk, and I’m really happy with the quality. As a result, I’ve been able to lower the price for the standard 1m length. If you need longer harnesses, I still make those by hand, so they’re a bit more expensive.
- Tesla LDU Harness: This is a newer product that I make entirely by hand. It features a dedicated 4-core shielded cable for the encoder wires, along with the same color-coded, heat-shrink-labeled design. I hope this helps simplify the process for anyone using an LDU with Openinverter boards.
Cheers!
