Throttle Pedal Question
Posted: Sat Dec 21, 2024 6:28 am
by phillipschip
I recently acquired a 2012 Leaf throttle pedal/pigtail, and tried hooking it up on the test bench. I wired it correctly based on research of past posts. When I put the unit in drive, I get immediate full throttle. I started with defaults and then tried adjusting some settings (potmin/ampmin/slipstart) but nothing really changed. This seems like a pretty common unit that people use. Could someone share with me the settings that have worked with this pedal? Is there some type of calibration procedure I need to do? Things have been working fine while testing with a standard pot so far. Thanks! Chip
Re: Throttle Pedal Question
Posted: Sat Dec 21, 2024 9:56 am
by m.art.y
phillipschip wrote: Sat Dec 21, 2024 6:28 am Is there some type of calibration procedure I need to do?
Every throttle pedal has to be calibrated and calibration procedure is described in detail in one of the Zombieverter videos on the openinverter wiki. I know it is kind of time consuming watching these videos but I don't see how one can move forward on this without doing that.
Posted: Sat Dec 21, 2024 10:18 am
Yes. You watch any of the videos? You clearly are just winging it, I hoped the fire you had would make you a bit more careful but seems not to have slowed you. Please follow the provided information and steps.
Map Pot1 and Pot2, the setup min and max accordingly.
Posted: Sat Dec 21, 2024 10:21 am
by J0hannes
Posted: Sat Dec 21, 2024 4:46 pm
by phillipschip
Thanks very much for the guidance. I’ll check it out! All most all of this is totally new to me so I appreciate your help very much :)
tom91 wrote: Sat Dec 21, 2024 10:18 am Yes. You watch any of the videos? You clearly are just winging it, I hoped the fire you had would make you a bit more careful but seems not to have slowed you.
Thanks for the concern Tom and I appreciate the advice. Rest assured, I’m going very slow and being very careful. All testing at LV, and everything except the motor is out of the car.
Posted: Sat Dec 21, 2024 5:48 pm
Wait why is this topic in the subforum for Nissan?
Are you using a Nissan leaf throttle pedal?
Posted: Sat Dec 21, 2024 5:54 pm
by phillipschip
Yes, I am.
I just got the throttle calibrated and it's working great. (30 min into video 3) Thanks for the help on this :)
(For some reason, when hitting "save parameters to flash" they don't always save)
Posted: Sat Dec 21, 2024 11:13 pm
When the inverter is in run mode parameters don't save. For... Reasons :)
You have to stop first
Posted: Sun Dec 22, 2024 6:19 am
by phillipschip
I am working with a Nissan throttle pedal, but am using a Tesla SDU and OI board. Could someone please let me know where to connect the pot 2 wires? I've been going through those videos and It looks like there are connections on the Zombieverter , but II don't have any wires to connect to on my wiring harness for the SDU. Thanks!
Posted: Sun Dec 22, 2024 9:43 am
You connect it to either one of these (Zombie or SDU), not both.
Posted: Sun Dec 22, 2024 4:07 pm
by phillipschip
Thanks. My pedal has two sensors, a total of 6 wires. Currently I have 3 hooked up and I’m testing in “single regen”. It seems common to hook up all six and use it “dual channel” for redundancy/safety, any ideas where to connect those other 3? I only have a SDU with OI board installed-no zombieverter. Thanks!
Posted: Sun Dec 22, 2024 4:16 pm
The other triplet goes to what is sometimes labelled "brake sensor input"
https://github.com/jsphuebner/Tesla-Fro ... ctions.pdf
Posted: Sun Dec 22, 2024 4:18 pm
by phillipschip
Oh ok. I didn’t see a pot 2 on my harness. I’ll look again. Thanks!
Posted: Sun Dec 22, 2024 4:19 pm
oh that was quick. Edited, look above
Posted: Sun Dec 22, 2024 4:24 pm
by phillipschip
Here is a screenshot of my harness. I don't seem to have a pot 2 connection available.
Posted: Sun Dec 22, 2024 4:26 pm
by phillipschip
johu wrote: Sun Dec 22, 2024 4:16 pm The other triplet goes to what is sometimes labelled "brake sensor input"
Would that be "Brake Transolver +5v" on mine? Thanks!
Posted: Sun Dec 22, 2024 4:29 pm
yes, pins 10, 18, 19
Posted: Sun Dec 22, 2024 4:33 pm
by phillipschip
Ok thanks. So I wouldn't use the "brake transolver ground"? Just hook to chassis ground?
Posted: Sun Dec 22, 2024 9:53 pm
Oh yeah, brake transolver ground. Missed that
Posted: Mon Dec 23, 2024 4:36 am
by phillipschip
johu wrote: Sat Dec 21, 2024 11:13 pm When the inverter is in run mode parameters don't save. For... Reasons :)
That would be the issue :)
Is there any way to put the inverter in "stop" mode other than turning off the ignition?
Posted: Mon Dec 23, 2024 8:24 am
by Bratitude
phillipschip wrote: Mon Dec 23, 2024 4:36 am That would be the issue :)
Yes… stop inverter button in the web interface
Posted: Tue Dec 24, 2024 5:29 am
by phillipschip
Just out of curiosity, Is the “stop inverter” button a safe way to shut down the inverter even when the motor is spinning?
Posted: Tue Dec 24, 2024 12:26 pm
Not really. It always opens the contactor
