ZombieVerter stand by current ?
Posted: Sun Dec 15, 2024 1:35 pm
by snelly
ZombieVerter stand by current, seems I need to keep it on trickle charge or is it better to swich it on with ignition ?
on switching it with ignition, I find wifi links OK but only see the menus with no data sometimes?
Re: ZombieVerter stand by current ?
Posted: Sun Dec 15, 2024 1:57 pm
Zombieverter is designed to be permantley powered. It draws around +/-150mA on standby
Posted: Sun Dec 15, 2024 7:05 pm
by snelly
OK thanks,
If I would use a battery disconnect when not in use for a a while, Is there a boot up time before turning the ignition back on?
Posted: Sun Dec 15, 2024 7:14 pm
No there is not particularly long boot up process, you just need to keep in mind that things like an ISAshunt and such need to be running to precharge. So best to give it a few moments before turning ignition on.
