Fully working electrical/ electronic setup for an EV conversion
Posted: Tue Dec 10, 2024 7:57 pm
by VWJoe
Fully working electrical/ electronic setup for an EV conversion that includes the following,
- Zombieverter on 2.17A Software that includes regen. Mounted in a metal case
- BMS, an Arduiro-based shield with the MAX17841 and Canbus, reads batteries and reports via Canbus the following voltages and temperatures. It also balances cells and calculates capacity. Finally, it reports voltages and status to the Display.
- Leaf Stack 2019 (low milage) including Leaf Motor, including Gearbox, Leaf Inverter 110 kW, Leaf PDM 6.6 kW charge
- HV Batteries, 16 Module CATL 2.73kWh, 43.6 kWh total.
- VPC (Vehicle Power Control) controls the power distribution to Zombieverter, BMS, Inverter, and PMD to minimize current in standby. Input triggers from door opening, Ignition, and charge flap enable quick start-up and timed switch-off.
- Fusebox with relays
- HV Fuse 250 amp
- Display, showing gear select, high and Low voltage, high and Low temperature, SOC, warnings, charging, charge rate, range, usage, torque, and available torque.
- Throttle, Mini Surf Pedal design
- IVT Shunt mounted in the Contact box.
- HV Contactor Box with pre-charge, +ve, and _ve contactor controller by the Zombieverter.
- Type 2 charging port
- Complete wiring loom that connects the above, including can bus
Comes with all the software supplied to allow you to modify to meet your needs. Happy to supply support after purchase. Only requires hardware to complete the conversion, mainly the gearbox connection and battery box.
Can be demonstrated working.
Located in Wiltshire
£7,500
Please PM me.
