Is there an open source VCU for the Leaf?
Posted: Sun Nov 24, 2024 9:42 am
by Pagdog
It seems the only options are commercial projects at several hundred dollars. Am I missing the open source projects?
Re: Is there an open source VCU for the Leaf?
Posted: Sun Nov 24, 2024 10:17 am
by royhen99
Posted: Sun Nov 24, 2024 7:10 pm
by catphish
As royhen99 says, the open source VCU you are looking for is ZombieVerter. This works great with Leaf hardware as well as some others.
Posted: Fri Dec 06, 2024 10:47 am
by Alibro
If you want to do it really cheap then use an Arduino Due with Damiens Nissan Leaf code but if several hundred dollars for the VCU is an issue then you're probably in the wrong place.
