Deleting canbus modules
Posted: Fri Nov 01, 2024 5:03 am
by Falcemach1
Hello :I'm still at it . I was reluctant to post more questions as some of the responses I received were rather rude but, here I am again.
I got the system from the 2021 Ford Mustang Mach-e that I fitted to my 1965 Ford Falcon to actually operate both forward and backward.
I have received enough fault codes on the Forscan to write a novel ! Is there some way to fool the system that the deleted CANBUS
modules are actually in place?
Re: Deleting canbus modules
Posted: Fri Nov 01, 2024 5:15 am
by T1Terry
I haven't read through to other thread, it started going off track a bit. Which modules are you trying to delete?
The Chinese Canbus systems seem to allow a lot of modules to be simply deleted, but there are a few must have units for them to switch on and not throw error codes resulting in system shutdown, before you even get started .....
T1 Terry
Posted: Fri Nov 01, 2024 7:02 am
by Jacobsmess
Most just spoof the original signals to make the ECU think they are still there or reuse the canIDs for other tasks.
Posted: Fri Nov 01, 2024 11:12 am
by jrbe
It may be possible to code out some of these modules. For example, if the rear view camera is an option in any markets, or an option Ford thought was worth adding as an option they likely will have a place say in the communications / can bus / gauge cluster to turn it off. It would likely be in a module that talks to all the different modules and expects responses from them.
If each module you want to delete is an option you might be able to change the coding to turn off these options like the factory would. I have no idea if Ford did this, and what high level of scan tool you'd need to accomplish it but I'd expect it's likely that they did.
There will likely be a few straggler modules that you can't do this with. Those will need some communications spoofed, basically replying to a health / info check request (s) with the correct / acceptable responses.
Posted: Fri Nov 01, 2024 1:23 pm
Falcemach1 wrote: ↑Fri Nov 01, 2024 5:03 am
I feel like a broken record but lets repeat. Log a fully working car, you will then need to boardcast those messages on the right CAN bus networks to fool the car into thinking they are there.
Posted: Fri Nov 01, 2024 5:34 pm
by Doig5710
I have had luck with disconnecting modules with vcds in VAG cars, with Fords I have only ever tried turning features off inside modules, it maybe possible with Forscan or the dealer tool but otherwise like Tom said you'll have to broadcast the canbus signals the other remaining modules are expecting to receive. Modern cars are very interconnected and can be extremely difficult to modify in the way you've got it setup using all the original modules.
Posted: Sat Nov 02, 2024 4:17 am
by Falcemach1
OK I do have access to the same year of car but, how do Record the data any broadcast messages which would be sent from such as the supplemental restraint system , frunk module , or image processing module , which are no longer connected to the system ?
Posted: Sat Nov 02, 2024 9:13 am
by Bigpie
You need to connect to the relevant can on the working car, record some action, IE driving, save the log. Clear repeat for charging etc.
Record the same bus on your setup, save log.
Compare files, filter out id's that are present on the log from your car and reply the remaining IDs to your setup. Hopefully you'll get it to do what you're trying to do. If so you can then start reducing the IDs sent until it stops. Then you know which are required.
If you've already got it driving back and forward, what are you trying to achieve that it's not doing?
Posted: Sat Nov 02, 2024 12:54 pm
by jrbe
I found a few things searching "Mach-e dbc file"
Looks like FORScan might be able to turn modules or maybe just options off,
https://www.macheforum.com/site/threads ... eet.24701/
https://github.com/sillygoose/mme-record
I'm sure there's more but I don't want to fall into this rabbit hole.
Posted: Sat Nov 02, 2024 6:59 pm
by Falcemach1
What I'm trying to is to get rid of the faults that display on the IPC I want to get the finished car inspected and fear that it will fail .The faults
show up as large printed faults on the IPC . I don't want to see that
Posted: Wed Nov 06, 2024 5:35 am
by Falcemach1
I have tried to post pictures but, I cannot. I have also tried to download SavvyCAN but, I have yet to find where to down load the program . All the sites I look at seem to be for computer experts that know their way around computer systems
Posted: Wed Nov 06, 2024 9:45 am
Falcemach1 wrote: ↑Wed Nov 06, 2024 5:35 am
Let me help you out.
If you fall at this hurdle buckle up, the learning curve is STEEP
Posted: Wed Nov 06, 2024 3:49 pm
by royhen99
This is fairly simple. Select "Full Editor & Preview" and then there is an "Attachments" tab with instructions.
Re: Deleting canbus modules [FINISHED]
Posted: Thu Apr 10, 2025 5:57 pm
by abetanco
Hello, I am just catching up with this thread. Were you able to get your Falcon running smoothly? The Mach E motors are so cool, but there doesn't seem to be a lot of info on them yet, regarding car hacking. Update us on your progress, when you get a chance, and thank you for sharing this project with us.
Posted: Wed May 07, 2025 4:14 am
by Falcemach1
Hello all : I’ve just had the car on the road. The power is great! I had a fella shorten the CV axles and that was a joke, they both broke. I had new axles made and they are great! I still need to hack the system to fool it to believe the deleted modules are still there. Suggestions anyone?
Posted: Wed May 07, 2025 7:32 am
tom91 wrote: ↑Fri Nov 01, 2024 1:23 pm
Posted: Wed May 07, 2025 12:00 pm
by jrbe
