Noise on throttle pot_in
Posted: Sun Oct 06, 2024 10:22 am
by ElMaco
While testing some erratic behavior on sel-dir (selecting ”gear”/FNR), I noticed noise on pot_in.
Decided to pull pot1 to ground. Still got noise, see attached screenshot from plotting. Pot1 is showing anything between 55 and 65 even though the input is pulled to ground.
Is this expected, or is there a way of filtering this with the settings/parameters?
Re: Noise on throttle pot_in
Posted: Sun Oct 06, 2024 12:26 pm
that's normal, unfortunately. It is slightly filtered and more importantly it is filtered even more before entering the control loop
Posted: Sun Oct 06, 2024 12:36 pm
by ElMaco
Thank you @johu,
Then I don’t need to think more about how to fix that 😅
So the trick is to set potmin a little bit above the noise, right?
