LEM CAB300 C/SP2 Current Sensor
Posted: Fri Sep 06, 2024 6:10 pm
by snelly
Hi
I have a LEM CAB300 C/SP2 Current sensor, that is making a hi pitch noise about 18khz, running of bench PSU
the can message are OK, has anyone tested one before and hared them?
Re: LEM CAB300 C/SP2 Current Sensor
Posted: Fri Sep 06, 2024 7:02 pm
by m.art.y
snelly wrote: Fri Sep 06, 2024 6:10 pm Hi
Do these need to be powered with 12v or 5v? :)
Posted: Fri Sep 06, 2024 7:09 pm
Posted: Fri Sep 06, 2024 7:16 pm
by snelly
on 12v
scope the 12v supply and its very clean
Posted: Fri Sep 06, 2024 7:20 pm
by snelly
have not had any luck decoding the can
Posted: Fri Sep 06, 2024 7:23 pm
Its not hard, info is in the datasheet.
Mind posting what your recieved CAN looks like? Where did you get the sensor from?
Posted: Fri Sep 06, 2024 8:22 pm
by snelly
it was from ebay looking at the can signal its just ____-______-______-_____- so the timing interval is 19khz so looks like the sensor integral dc dc switching noise i can hear.
conclusion is the senser is duff
thanks for every ones help
Posted: Fri Sep 06, 2024 9:26 pm
by larsrengersen
Think there are some fake China copies around. I made that mistake one day when they were hard to source. Threw them away and now only use and stock original ones bought from LEM directly myself.
Posted: Sat Sep 07, 2024 7:22 am
by snelly
It was from a used car braker not in antistatic rapping, have you any in stock?
Posted: Sat Sep 07, 2024 10:58 am
by m.art.y
Has anyone tried to configure those for a different CAN speed? It says in the datasheet they are configurable. Wonder how? I would need 125 kbps speed 😊
Posted: Sat Sep 07, 2024 5:38 pm
by larsrengersen
snelly wrote: Sat Sep 07, 2024 7:22 am It was from a used car braker not in antistatic rapping, have you any in stock?
Yes https://www.evcreate.com/shop/charging/ ... nt-sensor/
by larsrengersen
m.art.y wrote: Sat Sep 07, 2024 10:58 am Has anyone tried to configure those for a different CAN speed? It says in the datasheet they are configurable. Wonder how? I would need 125 kbps speed 😊
The CAB300 is fixed at 500 kbps. Some CAB500's can be reconfigured.
Posted: Sun Sep 08, 2024 5:51 pm
by m.art.y
Does anybody know if orientation of the CAB300 matter? It can be mounted with the front side with LEM logo facing the battery and with the back side facing the battery. I mean will current reading be positive or negative or it won't have any difference? 😊
Posted: Sun Sep 08, 2024 5:56 pm
From the datasheet
Installation requirements in this datasheet for the CAB sensor range.
https://www.lem.com/sites/default/files ... eet_v1.pdf
Posted: Mon Sep 09, 2024 8:07 am
by m.art.y
tom91 wrote: Sun Sep 08, 2024 5:56 pm image.png
From the datasheet
Hi, sorry for non technical person is the positive current when it is drawn from the battery through the negative busbar?
Posted: Mon Sep 09, 2024 10:34 am
Who knows, up to you and your BMS.
Posted: Mon Sep 09, 2024 3:42 pm
by snelly
hi thanks I now got a new IVT-S-300-U3-I-CAN1-12/24 instead, by the way could not get on you website it was block my end
Posted: Sun Jan 19, 2025 3:05 pm
I noticed CAB300 pdf is not available anymore. I think there is a lot of those stil available from Outlander cars...
I am posting a file for sp2 version here for future...
Posted: Sun Jan 19, 2025 3:13 pm
I found CAB300 connector, which is CAB500 connector as well:
4P Female P/N 1473672-1
Pins Female Crimp 1123343-1
Posted: Sat Nov 08, 2025 4:26 pm
by m.art.y
Anybody had CAB300 sensor die on them? They are either very sensitive when you accidentally mix CAN wires or are just prone to failure as two died on me in a short time. It still sends it's message but only savvycan can read it as the voltage between CAN wires is only 300mv. You connect it to the bus in the car and bus goes dead.
