Hi, I am looking to convert my Leaf Chademo to CCS by using the Foccci board. Does anybody have any experience with it?
Will the Focci board understand the Leaf Chademo talk to make the CCS2 work?
mvg
Paul
Saab 93 cabrio (Leaf drive train and battery)
You just need to find out the battery pack voltage which is not on the chademo CAN
SoC is available, maybe you can calculate a rough offset and gain to convert it to voltage
Re: Foccci board as Chademo to CCS conversion
Posted: Mon Aug 12, 2024 11:56 am
by PaulHeystee
Thanks!, I think i can arrange something. If this works I can now have a permanent CCS2 on my Saab, instead of the cumbersome and expensive adapter. I am planning to built the second one, again Leaf (160 kW), however, this time with Peugeot battery modules.
Posted: Mon Aug 12, 2024 12:33 pm
by uhi22
Great project! Together we will make this work. In case we need to adapt/extend the software, it would be helpful if you have the possibility to log the CAN (e.g. with SavvyCAN) and to make a serial log of Foccci (using a serial-to-USB adapter and any terminal program).
Posted: Mon Aug 12, 2024 6:05 pm
by PaulHeystee
I have the battery pack voltage from the Leaf BMS, so that's no problem. I only need to find a way to get this can message to the Foccci.
I am surprised that the Chademo does not have the pack voltage included in it's CAN set.
Posted: Tue Jun 24, 2025 6:11 pm
by uhi22
Not fully on-topic, but very interesting nevertheless:
- osexpert has ported the clara software to the china CCS-chademo-adapter. Seems to run quite well.
- The missing battery voltage is estimated based on the announced max voltage(?) and the SOC. This is not perfect, but good enough.
