Strange throttle response
Posted: Tue Jul 16, 2024 7:13 pm
I am facing very strange throttle response.
Checking the throttle end values I get around 33 on the pot-value in "idle" and around 3980 on full throttle. Both values are fluctuating a bit, full throttle more than idle. I have set potmin and potmax to 20 and 3995 to get some margin.
When engaging forward (or reverse, just the same) and then pushing the throttle, nothing happens until about 1000 on the pot-value. Then it revs up to 3000 rpm, which is the rev limit. Nothing happens giving more throttle. When getting under approx 1000 on the pot-value the motor calmly slows down to a full stop.
Obviously I want a proportional throttle response from 0 to 3000 rpm.
What am I doing wrong?
Parameters:
potmin: 20
potmax: 3995
potmode: 0 (SingleRegen)
pot2min: 100
pot2max: 4000
fmax: 200hz (~3000 rpm)
polepairs: 4
throtmax: 100%
throtmin: 0%
My setup:
Nissan leaf EM-57
Rev 3 board
FW 5.00.R-foc
Curtis ET-134 throttle (0-5V) & FNR (12V) combo. Throttle supplies 0V at idle and 5V at full throttle
Parameters:
potmin: 20
potmax: 3995
pot2min: 100
pot2max: 4000
polepairs: 4
throtmax: 100%
throtmin: 0%
My setup:
Nissan leaf EM-57
Rev 3 board
FW 5.00.R-foc
