Thanks:) Going to try spinning a motor open loop at the weekend to make sure the drivers are working correctly.
Re: Prius Gen3 Inverter Hacking
Posted: Thu Feb 21, 2019 7:33 pm
by Jack Bauer
The Prius Gen 3 inverter is now responding to gate drive signals.
Posted: Sun Feb 24, 2019 3:10 pm
by Jack Bauer
Motor spinning with the Prius inverter. Will get some video done in the next few days.
Posted: Mon Feb 25, 2019 4:24 pm
by Jack Bauer
More progress on the Prius :
Posted: Mon Feb 25, 2019 5:31 pm
by johu
Nice!
Maybe this is a silly question: the package includes 2 3-phase inverters and one HV to 12V DC/DC converter? And none of that HV to HV boost rubbish?
Posted: Mon Feb 25, 2019 6:23 pm
by Jack Bauer
It has 2 3 phase inverters, a dc dc converter for 12v and a buck boost module comprised of an igbt half bridge and inductor. This can either be ignored or possibly used for hv battery charging.
Posted: Thu Feb 28, 2019 4:07 pm
by Jack Bauer
Got started on the logic board design today. Three micros in total
Posted: Thu Feb 28, 2019 5:14 pm
by arber333
Can you tell how would you distribute logic units? Are they full blown Johannes units?
I recommend adding Lebowski brain as MG2 to have sensorless BLDC generator or rear motor application possibility.
Also i wonder if it wouldnt be good to account for buck/boost module as EMW charger? Hm... my mad scientist brain is thinking of charge pump application for charging from different sources like 3phase AC, single phase generator, DC solar source, DC battery extender etc...
Posted: Thu Feb 28, 2019 6:34 pm
by Jack Bauer
i think the design should handle most applications. There are two complete Johannes brains and an atmega 328 to handle the buck/boost and 12v dcdc converter control. I'll be uploading everything to github in a few days.
Very nice!
Only thing is the bypass caps of the resolver (C47, C78). 10µF proved a bit to small when I tested. I got power supply oscillations. I'd recommend at least 100µ.
Posted: Sat Mar 02, 2019 8:45 am
by Jack Bauer
Thanks guys. I'm going to call this one HSD : Heubner Synergy Drive
Posted: Sun Mar 03, 2019 11:52 am
by sonachan1
Damien, I've just emailed over some notes to your evbmw address.
Posted: Sun Mar 03, 2019 4:33 pm
by Jack Bauer
Go that. Thanks a lot
Making progress ....
Posted: Mon Mar 04, 2019 11:01 pm
by dima
Why not make "Expansion Board" just like Leaf, standardized v3 can be dropped instead of another custom design.
Posted: Tue Mar 05, 2019 8:48 am
by Jack Bauer
The board space would be a problem. Also the pcb skyline has to be low as the current sensors bracket sit on the top. If it was just a single inverter I could probably get away with it but this being the Heubner Synergy Drive it's a very tight layout especially as I'm trying to keep it single side surface mount to ease assembly.
Posted: Tue Mar 05, 2019 4:57 pm
by arber333
Jack Bauer wrote: ↑Sun Mar 03, 2019 4:33 pm
So you are convinced that you can supply 3ph power to one 6bridge (use only diodes) with second 6bridge connected to a motor and DClink will see 600V. Then you buck 600Vdc down to healthy 380Vdc with some overhead and supply the battery. That was also my plan .
I was considering using Ampera inverter as rectifier to get 600V, but IGBTs are on the edge. And Prius gives the benefit of built in halfh bridge and inductor.
Posted: Wed Mar 06, 2019 10:43 am
by Jack Bauer
Done
Posted: Wed Mar 06, 2019 6:15 pm
by johu
Wow, that looks like a lot of work, great achievement!
