Support for Axial Flux PMSM?
Posted: Tue Feb 04, 2020 1:57 pm
Hi Johannes,
Really impressed with your progress on the inverter. I have built my own DC controller but this AC stuff is next level.
I don't even begin to understand all the math and transforms that go into making this work. Well done!
Can you tell me if this inverter would work with the axial flux permanent magnet motors like the Avid AF140?
I am looking at using one of these for a conversion but having built my own DC controller I find it hard to accept having to pay $12500 USD for a suitable 250KW popular brand controller to run it. This works out to $18K Australian dollars.
I would love to use the AF240 but this requires two of these controllers.
Or better yet the AF430.... 4 controllers required...
I believe they run a resolver but I assume they wouldn't exhibit the reluctance torque that the IPM motors do in the higher RPM's?
Assuming if I used two controllers, each would reference their own resolvers and you would use the CAN bus to command the same throttle signal to both controllers at once?
Thanks.
Mike
Thanks.
Mike
