Page 1 of 1
Runing Tesla's inverter with an ATX power supply on the bench
Posted: Mon Apr 08, 2024 7:44 am
by AMP3R
Surely, it is no secret to many that in an ATX computer power supply there is 320 volts of DC voltage running on a large filter capacitor after the diode bridge. It is known that the diode bridge is not very powerful - only 6 amps.
Now the question. Is it safe to use such a power supply to spin the 3D7 motor several times on the bench without axle shafts?
Unfortunately, I don’t yet have either a battery or an oscilloscope to measure the ripples on the power supply. By the way, does anyone know what ripples are acceptable for inverters?
Re: Runing Tesla's inverter with ATX power supply on the bench
Posted: Mon Apr 08, 2024 8:14 am
by arber333
AMP3R wrote: ↑Mon Apr 08, 2024 7:44 am
Hm...
You could use such PSU as stabilized source. I would suggest that you use this solely for determining if precharge works correctly or of the motor spins unloaded. I would advise against using this for driving motor under any kind of torque.
viewtopic.php?p=8196#p8196
You can also make your own power supply. Simply use a diode bridge and large elcap. I have tested such rectifier with my autotransformer and i can make 360Vdc even for torque tests or charging. I would imagine stray
Posted: Mon Apr 08, 2024 8:48 am
by AMP3R
arber333 wrote: ↑Mon Apr 08, 2024 8:14 am
Hm...
Is it necessary to assemble a pre-charging circuit before the inverter? Or can I just connect the wires and plug the power supply plug into the outlet?
Posted: Mon Apr 08, 2024 10:20 am
by arber333
AMP3R wrote: ↑Mon Apr 08, 2024 8:48 am
Precharge wiring contains DC contactor + DC relay + precharge resistor.
As any HV assembly you need to test it in operation before you can rely on it to function...
