Page 1 of 2
Gen 3 Prius Transaxle P410 Makes Clunky Noise.
Posted: Tue Mar 26, 2024 2:39 pm
by Gregski
I would really appreciate your help trying to figure out what is making the clunky noise in this Gen 3 Prius P410 transaxle as I try and spin the motors for the first time. Damien informed me that the Zombie spins both MG1 and MG2. My power split device is NOT welded, the guts of the transaxle are 100% undisturbed and stock. Parking Pawl is NOT engaged, this has already been confirmed. (When engaged manually by hand the transaxle is locked and won't spin at all). By hand the output shafts spin in opposite directions in either the Parking Pawl locked or open positions.
I am able to spin both output shafts by hand in the same direction and it feels smoot, no noise, however I am doing this at a glacier speed compared to how fast the motors spin them electronically.
Transaxle and Inverter are from the same vehicle a 2010 Prius
VCU = ZombieVerter ver. 2.05A
Power Source = 300 watt, 30 volt, 10 amp bench power supply
I will provide more updates in additional posts this is just a call for help.
Re: Gen 3 Prius Transaxle P410 Makes Clunky Noise.
Posted: Tue Mar 26, 2024 2:40 pm
by Gregski
short video of my first spin attempt and the first time I discover the noise
Posted: Tue Mar 26, 2024 2:50 pm
by Gregski
direct link to Professor Kelley of WeberAuto demonstrating how the Parking Pawl works
Parking Pawl
Parking Gear
Parking Pawl & Gear Engaged
Posted: Tue Mar 26, 2024 4:06 pm
by tom91
So you are saying that spinning it by hand you feel no weird resistance or noise?
It is very possible your power supply is limiting or you getting a big drop across your tiny test wires into the inverter causing it to drop in and out.
Is there oil inside you gearbox? As it could be MG1 and MG2 fighting through the PSD.
Posted: Tue Mar 26, 2024 5:04 pm
by Gregski
tom91 wrote: Tue Mar 26, 2024 4:06 pm
correct spinning either of the output shafts I hear no noise, however that is after the gear reduction gear etc, I think the noise is clunking before that, but it's difficult to tell
Thank you Tom, tried it with a single battery module from a BMW 530e, these are roughly 60 volt modules with a big punch of current and thicker wires, still same noise
Posted: Tue Mar 26, 2024 5:35 pm
by Gregski
no fluid inside, adding some now
fingers crossed.jpg (9.65 KiB) Viewed 8321 times
Update from the future: 4 quarts in and still makes noise !!!
Posted: Tue Mar 26, 2024 5:59 pm
by tom91
Also MG1 has no way of transferring any torque, due to not having an engine in it.
Also this means no oil pump working, so locking the PSD is the only way to get the oil pump working and MG1 capable of providing torque.
Posted: Tue Mar 26, 2024 6:19 pm
by Gregski
tom91 wrote: Tue Mar 26, 2024 5:59 pm Also MG1 has no way of transferring any torque, due to not having an engine in it.
per Damien, the ZombieVerter VCU spins both motors, MG1 and MG2 and he claims MG1 spins the oil pump (no need to lock the input shaft, etc.)
I was under the impression per Professor Kelly of Weber Auto that only the input shaft spins the oil pump, but what do I know.
I will try and post the direct link to that section in the video here:
Posted: Tue Mar 26, 2024 6:30 pm
by tom91
https://toyota-club.net/files/faq/21-12 ... n.htm#P410
Input shaft does spin oil pump and the PSD. So if you weld the PSD it means if you lock the PSD, input shaft spins with the MG1.
Here is the mechanical system diagram. gets quite complex due to the PSD
Good document with pictures and graphs and drawings.
https://digital.library.unt.edu/ark:/67 ... 432/m1/47/ https://digital.library.unt.edu/ark:/67 ... 007833.pdf
Posted: Tue Mar 26, 2024 8:38 pm
by Gregski
Update 3000:
i can lay under the car and spin both output shafts in same direction and watch the input shaft spinning, all smoothly no clunking noise
Posted: Tue Mar 26, 2024 9:23 pm
by tom91
In the weber video the oil pump drive shaft.
Posted: Wed Mar 27, 2024 12:41 am
by Gregski
This is just a WeberAuto video showing how the Gen 3 Prius Transaxle uses the final drive ring gear to lubricate itself by splashing the fluid around
Posted: Wed Mar 27, 2024 5:22 am
by Gregski
so we went... Def Con 4
with the transaxle split into an open faced sandwich, spinning MG2 by itself with the final drive gear removed we noticed that it pulsates either always in the same spot or maybe two
we thought the Prius throttle pedal may have been bad, so first we recalibrated it, then we tried it in Single Channel mode, then we replaced it with a 2010 Honda Fit pedal and still same results
however when we spin MG1 by itself it spins smoothly no noise no pulse
I hope to upload the video tomorrow
Posted: Wed Mar 27, 2024 7:34 am
by Bigpie
Might as well weld up the PSD now it's there
Posted: Wed Mar 27, 2024 10:04 am
by tom91
Gregski wrote: Wed Mar 27, 2024 5:22 am with the transaxle split into an open faced sandwich, spinning MG2 by itself with the final drive gear removed we noticed that it pulsates either always in the same spot or maybe two
Do you hear any abnormal noises from bearings or gears when split apart like this?
There is going to be firmware soon that allows spinning of each Mg separately for even more testing.
I agree with Jamie on welding the PSD. Make sure to plop it in the ring gear on on the MG1 sun gear when welding so the gears are aligned.
Posted: Wed Mar 27, 2024 2:36 pm
by Gregski
tom91 wrote: Wed Mar 27, 2024 10:04 am Do you hear any abnormal noises from bearings or gears when split apart like this?
I do not that's what's bizarre, without the final drive gear what I call the differential it spins by hand smoothly like a Swiss watch. The reason I spin it without the diff is two fold, one it is easier, and two the diff wobbles a bit with only bearing support on one end with half the case off.
Also when spinning MG2 with electricity, out of the corner of my eye I saw my 30 volt bench power supply spiking to like 57 volts as if regen was pink ponging it back and forth.
Posted: Wed Mar 27, 2024 2:40 pm
by Gregski
Bigpie wrote: Wed Mar 27, 2024 7:34 am Might as well weld up the PSD now it's there
baby steps.jpg (5.79 KiB) Viewed 8163 times
Posted: Thu Mar 28, 2024 1:13 am
by Gregski
tried a complete second Resolver wire harness today, and still same problem
Posted: Thu Mar 28, 2024 4:25 pm
by Gregski
Happy to report the problem has been fixed, I will leave the technical explanation to the masters. Hope to update a happy motor spinning video soon.
Posted: Thu Mar 28, 2024 4:36 pm
by tom91
Long and short of it is, The zombie was thinking the inverter was reporting a really high temp so it was cutting throttle.
Turns out the Zombie was looking at the wrong byte in the serial comms with the inverter. This is now being worked on by Damien with my support to resolve this and verify the other information from the Prius Inverter.
"quick fix" is setting temphsmax to 300.
Posted: Thu Mar 28, 2024 10:35 pm
by MattsAwesomeStuff
tom91 wrote: Thu Mar 28, 2024 4:36 pmTurns out the Zombie was looking at the wrong byte in the serial comms with the inverter. This is now being worked on by Damien with my support to resolve this and verify the other information from the Prius Inverter.
So I'd presume Greg is the first to use the Zombie for a Prius then, as this should be consistent across the platform, no?
This underlines how hard the work Damien is doing is. One little thing here or there, no bueno.
Kudos to Greg for disembowelling his transaxle all over the garage floor chasing down and eliminating possible causes.
Posted: Thu Mar 28, 2024 10:39 pm
by tom91
MattsAwesomeStuff wrote: Thu Mar 28, 2024 10:35 pm So I'd presume Greg is the first to use the Zombie for a Prius then, as this should be consistent across the platform, no?
This is down to the Toyota Prius Gen3 with OEM control yes. Damien only spun it up on the bench.
Damien with my support is getting through bugs alot quicker now, always good to have a second set of eyes who is clued up on the code base.
Posted: Thu Mar 28, 2024 10:40 pm
tom91 wrote: Thu Mar 28, 2024 10:39 pmDamien with my support is getting through bugs alot quicker now, always good to have a second set of eyes who is clued up on the code base.
Go team.
IIRC Damien hates programming anyway.
Posted: Thu Mar 28, 2024 11:09 pm
by royhen99
Did today's testing unequivocally show that the inverter temperature is signed 8 bit?
If so then the GS450 tmphs/temp_inv_water still needs fixing
temp_inv_water=int8_t(mth_data[42]);
Posted: Thu Mar 28, 2024 11:14 pm
by tom91
royhen99 wrote: Thu Mar 28, 2024 11:09 pm Did today's testing unequivocally show that the inverter temperature is signed 8 bit?
Working through them all one by one, yes the temps are most likely reported in int8_t as IS300H threw problems below zero due to roll over.
Trying to pull all the coding inline, alot is based on knowledge from bench tests where not everything can be fully explored.
